2001 Dodge Ram 4x4 front u joint #2964421
09/15/21 02:56 PM
09/15/21 02:56 PM
Hamburg, Pa.
72 RR DUDE Offline OP
Hamburg, Pa.
On my 2001 Dodge Ram 4x4 it is time to change the front axle shaft u joints. So is there any greaseable joints available and what is the best u joint out there to use ??
Re: 2001 Dodge Ram 4x4 front u joint [Re: 72 RR DUDE] #2964557
09/15/21 09:45 PM
09/15/21 09:45 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
use a spicer u joint.
Re: 2001 Dodge Ram 4x4 front u joint [Re: GarageDodge] #2964560
09/15/21 09:50 PM
09/15/21 09:50 PM
Alberta
440_Offroader Offline
Alberta
iagree
Re: 2001 Dodge Ram 4x4 front u joint [Re: 440_Offroader] #2964580
09/15/21 10:57 PM
09/15/21 10:57 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Originally Posted by 440_Offroader
iagree
iagree too! But hey...be careful not to tear that axle seal during you R&R or you'll be pulling all apart again.
Re: 2001 Dodge Ram 4x4 front u joint [Re: Fat_Mike] #2964624
09/16/21 08:03 AM
09/16/21 08:03 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
I agree... go with Spicer. Just replaced the ujoints and the hub bearings on the 2006. I'm going to regret not doing the ball joints at the same time but they're in good condition. A good amount of anti-seize on the hub bearings will make that job much easier.
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Re: 2001 Dodge Ram 4x4 front u joint [Re: jughed] #2964700
09/16/21 12:50 PM
09/16/21 12:50 PM
moparx Offline
moparx  Offline
if it were mine, i would go with non-greaseable spicer joints.
it seems the greaseable joints just don't last.
only my experience. your mileage will vary.
beer
