Re: Questions about pinion snubbers
#29635
09/17/06 02:46 PM
09/17/06 02:46 PM
Posts: 2,734 Charlotte, NC
446acuda
Charlotte, NC
Welll ....neither do I ..... I "lost" mine in 70's !
It seems to have "disappeared" after I bought a set of budget SS spring back in the early 70's.
The last time I ran my 62(2003) ...... it went 12 teens with a 2.76 gear with a 7" DOT tire....thru the muffs with iron manifolds.
Saying "NO to a PS" seems to be wurkin' furrr me !
Namvet-did you used to go by the username: Dr/MrFiberglass on this board years ago?? I think he had a '62 that he said went 12's with 2.76 too.
[Re: 446acuda]
#29636
09/17/06 02:54 PM
09/17/06 02:54 PM
Posts: 10,968 Hampton, Ga.
70dart360
Green Meister
Green Meister
Hampton, Ga.
Yep, Doc Fiberglass was permantly banned years ago I though. Kinda for the same reasons as his post in this topic. ..
70 Dart Swinger
72 D-100 440 shortbed
76 Pinto, 68k 21mpg!
[Re: IronWolf]
#29638
09/18/06 04:25 PM
09/18/06 04:25 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
It works for some, it doesnt for others. It shouldnt be such a raging debate really. I like them, but there are a few cars I know for whatever reason dont run well with them.
[Re: IronWolf]
#29643
09/18/06 07:02 PM
09/18/06 07:02 PM
BRawls
super gas
super gas
I'm just tired of these myths being perpetuated by the ignorant. The myths don't help at all..
I'm not sure WHAT myths are being perpetuated. I know that a snubber worked on my car with SS springs, but not on other peoples. There are so many variations in drivers, cars, motors, converters, etc. how can anybody be so sure it will or will not work? I don't see the real problem, if you don't need a snubber, don't use one and visa-versa. If your SS springs work the way some people say, it won't even make contact with the floor. So the only down side is carring 5 lbs. of extra weight.
[Re: BRawls]
#29644
09/18/06 08:42 PM
09/18/06 08:42 PM
Posts: 485 Northern Wisconsin
greenduster
mopar addict
mopar addict
Northern Wisconsin
Hay guys. Use what works for you and let the others use what they like. SS springs and a pinion snubber works for me. The car launches hard and it may not even hit the PS.
[Re: greenduster]
#29645
09/18/06 09:35 PM
09/18/06 09:35 PM
Posts: 2,111 Bowie, MD
Reggie
Bowie, MD
Whew!! Lets add this one to the list of "Official Beaten Dead Horses"...... 340 or 360 318 or 360 Big Block or Small Block Stroker or Stock Stroke Eddy or Cast Iron Heads Auto or 4-Speed 727 or 904 8.25" any good? Eddy or Holley Carb 741 any good? 742 vs 489 Green vs OEM-style axle bearings Turbo vs Supercharger Clutch fan vs. Flex Fan Rubber vs Poly vs Polygraphite Ported or Manifold Vacuum
[Re: Dave_J]
#29647
09/19/06 03:20 AM
09/19/06 03:20 AM
Nanvet has been banned for some reason.
How do you know that?
[Re: plymouthfan]
#29649
09/19/06 08:17 AM
09/19/06 08:17 AM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
I think the snubber is more than just to stop spring wrap. As the tires rotate forward the axle housing counters and wants to rotate backwards. The axis of rotation at this point is the axle shaft. When the snubber contacts the floor board the housing can no longer rotate on the center of the axle shaft. The momentum of the housing rotation now tries to lift the car up off the ground similar to when you twist a flat blade screwdriver to seperate 2 parts. This places more force downward onto the tires.
Sounds great in theory.
But I wonder if Snubbers are like helper springs. If you put a mondo spring pack on a truck, you don't need helpers. But if you want a compromise you put a lighter spring with a helper that comes into play when loaded only.
Maybe a pinion snubber is a great way to allow for a decent ride but also keep against wrap up when the customer wants to romp on it.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: CJK440]
#29650
09/19/06 11:14 AM
09/19/06 11:14 AM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
CJK440, you nailed it. Thats what a shubber was ment to do. Its true some cars dont need one, and tapeing the front part of the springs does help on other cars.
And just a side note, after talking to my favorite Modorator (I like them all), I found out Namvet was and is Dr Fiberglass and is banned agian. DaveJ
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: IronWolf]
#29651
09/19/06 11:51 AM
09/19/06 11:51 AM
moper
Columbia, CT
Oh, and you can drive Moper - how's that ??
Iron, anytime I can get the chance I love to drive others' cars. I'd be privileged to take yours down the track. My point is tho, your car, and every other one, is it's own beastie. What works for you, or for the SE guys, doesnt work accross the board. Neither does "the other side's (pro-snubbers..)" arguments. You use stock eliminator as an example. The friends I have that ran it dropped the clutch at 6800, running 5.13 gears in a 3500lbs car on a 9" slick IIRC. So anything that helps soften that apply for a milisecond or two helped the 9" wide tires grab. SO yes, I wouldnt be putting a snubber on one. Your typical stock 340 E body doesnt need one either, until you seat 4 adults and a full tank of fuel in it. That's what the factory needed them for. I'm not disagreeing with your opinion, just the delivery. I'm saying each single application, and in many cases each single person working on the stup will require something for that application. I can tell you, there are many more running snubbers, than those that run none or those that run devices such as Cal Tacs and Slide-a-links all combined. And they work fine for them. No biggie really, but I wouldn't swear loosing it is the be all end all of solutions. It's not. At least not on every car.
When do you get up north?
