Re: changed posi , now gears make lots of noise!
[Re: 69Cuda340S]
#296359
04/22/09 03:24 PM
04/22/09 03:24 PM
Posts: 1,349 warfordsburg, PA
dirt
warfordsburg, PA
It was 10 years ago and i am just now getting around to reusing it. i only put about 60 miles on it since the shop worked on it. what would you torque the pinion bolt to? I may have had him swap the yoke , that would be the only reason to mess with the pinion nut. I should be able to torque the pinion nut down and set the lash and it should be good i would think,I remember him telling me he had to change the carrier bearings when he installed the other posi unit. but they were supposed to have been new. what would you set the lash at for used 3.91 gears?
[Re: polkat]
#296363
04/22/09 04:13 PM
04/22/09 04:13 PM
Posts: 1,101 Retired now in Tennessee
Chi_Town_Runner
It all depends on the case.
First, only the 489 case used the crush sleeve. The 741 and 742 cases used shim packs to set the pinion depth. On the 741 and 742 case (thanks to Dr. Diff), the pinion nut should be torqued to 140 ftlbs on a 10 spline and 280 ftlbs on a 23 spline.
There should be no play on the pinion. Take it out before you drive it any further and take it back to the guy who built it. The growl you hear could be the rear end eating itself up.
Good Luck,
Frank
Remember - 2 wrongs don't make a right - but 3 rights make a left!
[Re: 68Bullit]
#296365
04/22/09 04:38 PM
04/22/09 04:38 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
Man I sold a 741 case 3.91 posi that howled pretty bad. It was a good unit as far as I know, and never put any metal in the gear oil, nor did it have any sharp teeth (and I put WELL over 2000 miles on it). I've heard of many of these same cases with the 3.91 gearset that many people say were fine but just howled and were very loud. It's interesting that it didn't start until you removed the old posi for a good working one. FWIW, I'd say the guy set it up correctly
I have 3.91's in my dart , factory gear set,they do not howl , even with the metal particle laced oil because of the POS cone type sure grip .
Did you read all he posted , the pinion is LOOSE , how can you think it's set up correctly if the pinion is loose ?
[Re: JohnRR]
#296367
04/22/09 05:25 PM
04/22/09 05:25 PM
Posts: 571 Western NC
68Bullit
Western NC
"Seems" loose, and "some play" are references that the OP used IIRC.
Yeah, I did read all that he posted, and if you would read all of the entire thread you would see that there is uncertainty whether or not the yoke was even removed or not. The problem started after a working posi was installed, NOT before. No, it doesn't sound right that the yoke is loose, obviously. So, why have other units that were setup entirely correctly howled and made noises similar to what the OP described? That was merely what I was trying to point out.
[Re: stumpy]
#296368
04/22/09 07:04 PM
04/22/09 07:04 PM
Posts: 6,516 Santa Cruz, California
Lefty
Just to clear up the terms a little. Chrysler uses the name suregrip. GM is a posi. Some folks get upset when you use a chevy name for a Mopar rearend.
In 1966 Dodge called the clutch type LS in my 66 Coronet a "Power Lock"
[Re: JohnRR]
#296369
04/22/09 07:20 PM
04/22/09 07:20 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
John I too read is post and the previous posts. That is why I made the far previous statement that there should have been no need to take out the pinion to install the sure grip (if it was or is indeed loose), also made the statement that something was misassembled if it was quiet before and not after, and to get it set up right before driving it and a new wear pattern is established and the noise is irreversable. Again I repeat - But that being that these were quiet they need attention. ASAP.
[Re: MoparforLife]
#296370
04/22/09 09:40 PM
04/22/09 09:40 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
OK Unless the bearings have failed, there wasn't enough preload when they changed the yolk(if that was done. The original poster isn't sure) Remove shims( a little at a time) from behind the outer pinion bearing, and retorque the nut until it has preload again. Drive it, and see if the noise is gone. Hopefully it is. If the noise is stil present, it may already be beyond help. The proper way to install a sure grip carrier on a used set of gears, is ... 1)Measure AND RECORD the backlash setting 2)remove the carrier assembly with the ring gear on it. 3)transfer ring gear to sure grip carrier 4)install new sure grip and gear into center chunk 5)use the adjusters to get the backlash EXACTLY the same as was. If it's not, the pattern is now off, and it will be noisy. By not changing pinion depth, and putting the backlash where it was, the original pattern is still intact. If this procedure wasn't followed, Setting it up, may help, but a worn gear set needs to maintain it's existing pattern to not be noisy. A new pattern means noise. Pinion depth, should not have been messed with. If the guy who changed the yolk decided to change the depth, and set the pattern up fresh from what it was, it is screwwed, and will always be noisy
[Re: dave571]
#296371
04/22/09 10:40 PM
04/22/09 10:40 PM
Posts: 15,487 Florida
scratchnfotraction
with stumpy right there is your prob you gots a posi were a suregrip should be and its making noise now sorry,I could not help not saying it give doctordiff a call he will fix it
[Re: scratchnfotraction]
#296372
04/22/09 11:32 PM
04/22/09 11:32 PM
Posts: 364 Arkansas
kzcountry
Arkansas
with stumpy
I agree give Doctordiff a call. He will make it right. I just got my 489 case back yesterday, it had a howl and now quiet as can be.
