Re: Single battery 12V systems
[Re: fourgearsavoy]
#2962316
09/08/21 08:34 PM
09/08/21 08:34 PM
Posts: 11,728 Portage,michigan
B3422W5
Portage,michigan
I have the powermaster 1 wire 95 amp alternator( charges nicely from 1000rpm and up) with a big interstate battery..think its around 900cca Havent had a battery charger on the car in two years… running elect WP/ Fan/fuel pump/ msd, etc, etc, even after going rounds
[Re: B3422W5]
#2962320
09/08/21 08:44 PM
09/08/21 08:44 PM
Posts: 2,122 Byron, NY
W.I.N. Racing
Byron, NY
I have had great success with the Snyder Motorsports battery. I use two but can get 10 plus starts out of them before the need recharging.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: HardcoreB]
#2962419
09/09/21 10:04 AM
09/09/21 10:04 AM
Posts: 8,037 Tulsa OK
Bad340fish
Tulsa OK
There is people offering 14V batteries now as well. Would also require a charger but I think they play better with he electronics you already have.
68 Barracuda Formula S 340
[Re: HardcoreB]
#2962421
09/09/21 10:11 AM
09/09/21 10:11 AM
Posts: 16,932 NC
440Jim
NC
The current pulley ratio puts the alt rpm at it's critical limit...i already did maximize the pulley ratio/custom. The Powermaster alternators I have seen say,
[Re: Al_Alguire]
#2962975
09/11/21 01:46 PM
09/11/21 01:46 PM
Posts: 8,352 fredericksburg,va
cudaman1969
fredericksburg,va
One wire Toyota alt with big pulley, made sure battery was up before going to races Friday nite and Sunday stayed charged, regular bat in trunk. MSD, fuel pump and fan for water pump. Under 900 rpm amp gauge showed a slight discharge till rpm got up.
[Re: cudaman1969]
#2962997
09/11/21 02:31 PM
09/11/21 02:31 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
Guess I can ad we use a 16V Lithum in the dragster and a House of Payne mini one wire. Really no need for the charger unless its hotlap time and need quick cool down. I ran a lithium and no alternator in the Stratus, both cars have a fair amount of racepak stuff on board 2 O2's on the dragster and 8 on the Stratus.
[Re: Al_Alguire]
#2963012
09/11/21 03:27 PM
09/11/21 03:27 PM
Posts: 4,866 North of Detroit
HemiDart68
North of Detroit
I have used east coast auto electric alternators with real good luck.
As far as 12 vs 16, there are advantages and disadvantages. On my last build when I saw I had to reduce a bunch of things, and just would really be using the extra voltage for cranking I decided against it.
Sometimes i think people have problems starting, so just default to 16V when in fact the issues are elsewhere in the electrical system. Running proper size cables for alternator, starter etc. are important. I don't use chassis grounds, my whole system grounds back to battery, I firmly believe that helps a lot.
i like deka batteries.
In God we trust, all others pay cash.
www.lightnens.com (Home of the world's fastest Paint Job)
[Re: HemiDart68]
#2963194
09/12/21 10:42 AM
09/12/21 10:42 AM
Posts: 4,101 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
i like deka batteries. I share the same reasoning. I do believe Doug had /has adequate wiring materials. And he helped me with mine so, if anything mine is ignorant overkill in many opinions. This battery was quite old and I did a restoration/ decalcify procedure to it before I ever tried it...I never charged it before this. So the reserve was suspect. I know a 'hillbilly' jumpbox will solve my starting problems for the moment along with new battery and a more tenative 'replenishing' proceedure. It is a fast fix hopefully. Jumped it in the lanes that day (thanks SimonFast!), drove it directly to trailer and loaded it so it had 3? minutes of partial charging. When I got home 2 hrs later, it started 3 times during unloading. I'll have all winter to consider redesigning a different electrical system but, it'll likely be an expensive weight savings.
