Single battery 12V systems #2962204
09/08/21 03:10 PM
09/08/21 03:10 PM
Shelby Twp. Mi
HardcoreB Offline OP
Shelby Twp. Mi
I need to replace the 5 year old 12volt 40lb 800cca 115RC AC Delco battery group 34. My alternator outputs about 80 amps and won't charge the system at equilibrium with full accessories until about 1800rpm and that isnt fixable. I almost feel like I had a working system going, just the battery isnt deep cycle and its age. I'm looking for a good 12V battery for this application. And I'll bring a jump box to the track JIC. Not really considering 16v at this time. Besides needing a new charger, I HAVE READ that 16V should reduce voltage to the fuel pump (mines overkill now), Oxygen sensors, and possibly the Holley data dash. People I know charge the 16V between rounds anyway.
Re: Single battery 12V systems [Re: HardcoreB] #2962311
09/08/21 08:11 PM
09/08/21 08:11 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
What alternator are you running? The Toyota Denso alternator charges 14.6 volts as low as 600 RPM . For the last 12 years I have had this setup with a single 650 CCA battery and a 91 Toyota truck alternator with zero charging and starting issues twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Single battery 12V systems [Re: fourgearsavoy] #2962316
09/08/21 08:34 PM
09/08/21 08:34 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I have the powermaster 1 wire 95 amp alternator( charges nicely from 1000rpm and up) with a big interstate battery..think its around 900cca
Havent had a battery charger on the car in two years… running elect WP/ Fan/fuel pump/ msd, etc, etc, even after going rounds
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Single battery 12V systems [Re: B3422W5] #2962320
09/08/21 08:44 PM
09/08/21 08:44 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
I have had great success with the Snyder Motorsports battery. I use two but can get 10 plus starts out of them before the need recharging.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Single battery 12V systems [Re: W.I.N. Racing] #2962350
09/08/21 11:05 PM
09/08/21 11:05 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
What's the pulley ratio? Needs to be about 1-3 to spin the alternator quicker at low rpm. You could get a bigger alternator. Or go 16V as we discussed and don't look back. I struggled with 12v for 7 years. 16 v is WAY BETTER.
Doug
Re: Single battery 12V systems [Re: dvw] #2962378
09/09/21 06:05 AM
09/09/21 06:05 AM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
I was using the 31lb red top batteries for the last 10 years....Probably still will....I am trying out a 47lb XS3400D AGM battery this year....It has a ton of reserve and 1150 CCA ....The red tops work pretty well except for the reserve...So a good alternator is required..Best one I ever used is this one...I can turn everything on, and voltage is rock steady even at idle...
https://www.mechman.com/alternators...85-gm-natural-finish-includes-2-pulleys/
Re: Single battery 12V systems [Re: Dragula] #2962381
09/09/21 06:23 AM
09/09/21 06:23 AM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Buy this Alternator: Powermaster #857295-1. One wire, 145 amps at idle 175 amps top end. I just got one for myself. $246 thru Summit.
Re: Single battery 12V systems [Re: STEFF] #2962385
09/09/21 06:56 AM
09/09/21 06:56 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Mine has had the same optima red top in it since I put the car together 8 years ago. Car sat in the cold all winter, and I didn't even have to charge it this spring....just fired right up.
But power draw is probably a bigger issue than capacity. If you're taking out more than you can put in, it'll die eventually no matter how good of a single 12v you put in.
Re: Single battery 12V systems [Re: dizuster] #2962402
09/09/21 08:27 AM
09/09/21 08:27 AM
Shelby Twp. Mi
Shelby Twp. Mi
ALL good replies and i thank you. I'll try to respond to them all here. First, i cannot package a different alternator without major changes. (time) The current pulley ratio puts the alt rpm at it's critical limit...i already did maximize the pulley ratio/custom. I will check out Snyder...THANKS! I was looking at the XS series and specifically the 3400 but now I'm realizing most of these 'good' batteries will require a new charger...even the 12V's So, now I'm leaning towards a single 16V and removing the alt from the car! Then metering the specific circuits prudently.
Re: Single battery 12V systems [Re: HardcoreB] #2962419
09/09/21 10:04 AM
09/09/21 10:04 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
There is people offering 14V batteries now as well. Would also require a charger but I think they play better with he electronics you already have.
68 Barracuda Formula S 340
Re: Single battery 12V systems [Re: HardcoreB] #2962421
09/09/21 10:11 AM
09/09/21 10:11 AM
NC
440Jim Offline
440Jim  Offline
NC
The Powermaster alternators I have seen say,
Re: Single battery 12V systems [Re: 440Jim] #2962718
09/10/21 01:51 PM
09/10/21 01:51 PM
Shelby Twp. Mi
Shelby Twp. Mi
Yep!
Re: Single battery 12V systems [Re: HardcoreB] #2962719
09/10/21 01:53 PM
09/10/21 01:53 PM
Shelby Twp. Mi
Shelby Twp. Mi
At this point I'm replacing with a fresh non-agm 12V and using a jump pack. The off-season I'll do a light-weight 16V without an alternator....saving prob 30lbs combined.
Re: Single battery 12V systems [Re: HardcoreB] #2962949
09/11/21 12:59 PM
09/11/21 12:59 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW we use a single small 14lb Odyssey 12V Battery in the Vette. Starts that 17-1 plus, open spring pressure that would scare most SB with zero issues. We also have a myriad of racepak sensors to include 8 O2's and anyone who runs one knows how much power they rob. It also has a std SM one wire alternator, gotta have the juice for the power windows you know smile
Re: Single battery 12V systems [Re: Al_Alguire] #2962975
09/11/21 01:46 PM
09/11/21 01:46 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
One wire Toyota alt with big pulley, made sure battery was up before going to races Friday nite and Sunday stayed charged, regular bat in trunk. MSD, fuel pump and fan for water pump. Under 900 rpm amp gauge showed a slight discharge till rpm got up.
Re: Single battery 12V systems [Re: cudaman1969] #2962997
09/11/21 02:31 PM
09/11/21 02:31 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Guess I can ad we use a 16V Lithum in the dragster and a House of Payne mini one wire. Really no need for the charger unless its hotlap time and need quick cool down. I ran a lithium and no alternator in the Stratus, both cars have a fair amount of racepak stuff on board 2 O2's on the dragster and 8 on the Stratus.
Re: Single battery 12V systems [Re: Al_Alguire] #2963012
09/11/21 03:27 PM
09/11/21 03:27 PM
North of Detroit
HemiDart68 Offline
HemiDart68  Offline
North of Detroit
I have used east coast auto electric alternators with real good luck.
As far as 12 vs 16, there are advantages and disadvantages. On my last build when I saw I had to reduce a bunch of things, and just would really be using the extra voltage for cranking I decided against it.
Sometimes i think people have problems starting, so just default to 16V when in fact the issues are elsewhere in the electrical system. Running proper size cables for alternator, starter etc. are important. I don't use chassis grounds, my whole system grounds back to battery, I firmly believe that helps a lot.
i like deka batteries.
In God we trust, all others pay cash. www.lightnens.com (Home of the world's fastest Paint Job)
Re: Single battery 12V systems [Re: HemiDart68] #2963048
09/11/21 05:50 PM
09/11/21 05:50 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine had excellent wiring gauge and connections. The trouble was 15-1 at full timing and an alternator that has questionable output at idle. When you go late rounds in the heat there isnt enough time to fully recover the batteries. You need a better platform to start.
Doug
Re: Single battery 12V systems [Re: Al_Alguire] #2963189
09/12/21 10:13 AM
09/12/21 10:13 AM
Shelby Twp. Mi
Shelby Twp. Mi
I couldn't find any such battery. 12V /14lb
Re: Single battery 12V systems [Re: HemiDart68] #2963194
09/12/21 10:42 AM
09/12/21 10:42 AM
Shelby Twp. Mi
Shelby Twp. Mi
I share the same reasoning. I do believe Doug had /has adequate wiring materials. And he helped me with mine so, if anything mine is ignorant overkill in many opinions. This battery was quite old and I did a restoration/ decalcify procedure to it before I ever tried it...I never charged it before this. So the reserve was suspect. I know a 'hillbilly' jumpbox will solve my starting problems for the moment along with new battery and a more tenative 'replenishing' proceedure. It is a fast fix hopefully. Jumped it in the lanes that day (thanks SimonFast!), drove it directly to trailer and loaded it so it had 3? minutes of partial charging. When I got home 2 hrs later, it started 3 times during unloading. I'll have all winter to consider redesigning a different electrical system but, it'll likely be an expensive weight savings.
