sway bars #2963095
09/11/21 08:20 PM
09/11/21 08:20 PM
Richmond Ohio
alexdodge2 Offline OP
Richmond Ohio
I have a 1964 dodge custom 880 Been trying to find a dealer who sells front and rear sway bars for this car Any ideas?
Re: sway bars [Re: alexdodge2] #2963115
09/11/21 09:22 PM
09/11/21 09:22 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Good luck, had a 64 300 I wanted sway bars for, no dice, but this was in the early 90's. I ended up retrofitting the swaybar from an 89 Ram 1/2ton in the front. Fit pretty good.
Never did find anything for the rear.
Re: sway bars [Re: Sniper] #2963475
09/13/21 12:47 AM
09/13/21 12:47 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I have used off brand sway bars several times.
I've modified maybe 6 or 7 front sway bars from 1973-1987 Chevy 1 ton 2wd trucks for use in several A bodies, 2 B bodies and an E body.
The rear bar that ADDCO and Helwig sells can be adapted to fit your car since they hang below the axle and use simple mounts and hardware.
My experience is that for a decent street car, there needs to be a 100 front, 70 rear sway bar ratio. In short, if you have a 1 inch front bar, the rear should be 5/8". If the front is 1 1/4", the rear should be approximately 3/4".
You don't want the same size front and rear. You DON'T want a bar only on the rear.
Re: sway bars [Re: Sniper] #2963486
09/13/21 03:18 AM
09/13/21 03:18 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Isn't the 64 dodge custom 880 a C body? If so, maybe a stock C body setup from later years ? For the front at least.
Re: sway bars [Re: NachoRT74] #2963863
09/13/21 11:05 PM
09/13/21 11:05 PM
Richmond Ohio
Richmond Ohio
Looks like I'll be having to do some abdapting myself. Thanks everyone
Re: sway bars [Re: alexdodge2] #2965294
09/18/21 04:37 PM
09/18/21 04:37 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
You might want to talk to the guys @ Firm Feel they are Mopar people and can probably help get you setup.
Re: sway bars [Re: NachoRT74] #2965303
09/18/21 05:14 PM
09/18/21 05:14 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Cbody platform didn't start until 65. A 64 Custom 880 would be pretty much identical chassis wise to a 64 Chrysler.
That being said, you might be able to coax a Cbody bar in there but I think they were undersized for the original application and while better than no bar, for the same amount of effort, you can get something sized more appropriate.
I've heard the GM pickup bars from the 70's-80's are a better choice diameter wise and can be modified to fit fairly easily.
Kevin
