Re: Hard starting
[Re: B1MAXX]
#2962454
09/09/21 12:13 PM
09/09/21 12:13 PM
Posts: 4,769 Holland MI Ottawa
2boltmain
Holland MI Ottawa
The fuel very well may have evaporated during the cars non use time. Cranking the engine works the mechanical fuel pump and refills the float bowl/chamber of the carburetor.
Keep old mopars alive.
Re: Hard starting
[Re: 2boltmain]
#2962461
09/09/21 12:29 PM
09/09/21 12:29 PM
Posts: 6,240 nowhere
Sniper
nowhere
The fuel very well may have evaporated during the cars non use time. Cranking the engine works the mechanical fuel pump and refills the float bowl/chamber of the carburetor. I doubt sitting for one day would do that. My 51 will sit for 3-4 days and fire right up. Now it might be getting real hot and basically boiling off the fuel at shut down, but I doubt it's just from sitting one day.
Re: Hard starting
[Re: topside]
#2962587
09/09/21 08:45 PM
09/09/21 08:45 PM
Posts: 15,350 Omaha Ne
TJP
Omaha Ne
My AVS cars have all done that if the choke is inoperative, and if they sat/sit for a week or two regardless. Step #1, check the choke operation. On a cold motor remove the air cleaner and move the throttle 1/4" or so. The choke should close and have a slight spring tension holding it closed. Step #2. If the above is OK, check the ACC. pump shot by holding the choke open and exrcising the throttle. you should see two streams of fuel shooting into each primary bore. Who did the resto?
Re: Hard starting
[Re: TJP]
#2962600
09/09/21 09:20 PM
09/09/21 09:20 PM
Posts: 10,205 Someplace you aren't
SomeCarGuy
Do you have at least the 3/8 inch or so spacer that used to come in the rebuild kits?
That made a huge difference in the starting of the last car I chased this problem down on. With just a thin paper gasket I’d get some longer cranking even on a hit start. That spacer got me quick light off and I could go about one week without much issue cold starting a car with no choke. Any longer and it was gas down the carb time. Electric pump would help the situation if you are up for that.
I want my fair share
