What oil do you use on a solid roller? #2961252
09/05/21 02:15 PM
09/05/21 02:15 PM
Big Western Pencilveinya
U
Uncle Barry Offline OP
U
I've been doing some reading on this and I see some research that zinc in solid roller applications could do more harm than good due to carbon build up etc. What do you folks use? I've always used Rotella 15w40 with a bottle of Lucas engine oil break in additive and had good luck.
Re: What oil do you use on a solid roller? [Re: Uncle Barry] #2961260
09/05/21 02:47 PM
09/05/21 02:47 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Pennn Grade in everything for me.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: What oil do you use on a solid roller? [Re: Uncle Barry] #2961332
09/05/21 07:09 PM
09/05/21 07:09 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
I use straight Rotella 15w40 and the T&D rockers (adjusted hot to Comp Cam's specs) rattle like hell at idle. Not that it worries me any, but I read that w30 would quiet it down some.
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Re: What oil do you use on a solid roller? [Re: Uncle Barry] #2961419
09/05/21 10:18 PM
09/05/21 10:18 PM
Aren't all new production motors stock with hydraulic rollers? What oil do they use now work
Re: What oil do you use on a solid roller? [Re: Cab_Burge] #2961444
09/06/21 12:03 AM
09/06/21 12:03 AM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
Brad Penn here, I guess now it's Penn Grade. Good stuff.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: What oil do you use on a solid roller? [Re: Steve1118] #2961454
09/06/21 03:45 AM
09/06/21 03:45 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
15-40 delvac or rotella
Re: What oil do you use on a solid roller? [Re: Uncle Barry] #2961486
09/06/21 09:23 AM
09/06/21 09:23 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I spoke with Ray Barton the other day about his rocker system. He said not to run synthetic oil with roller cams on the street. Claims the bearings fail sooner if you do. We were talking about high lift cams on the street at the time, like .750+, i'm pretty sure thats what he was saying because i have run roller cams on the street with synthetic oils for years and never had an issue with .700" lift and a solid roller. Anyone else ever hear this?
Re: What oil do you use on a solid roller? [Re: Uncle Barry] #2961489
09/06/21 09:28 AM
09/06/21 09:28 AM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
15-40 Rotella
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: What oil do you use on a solid roller? [Re: mopar dave] #2961509
09/06/21 10:53 AM
09/06/21 10:53 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Never heard this, but I'm using hi zinc mineral.
.750/.680 lift.
Been great.
Re: What oil do you use on a solid roller? [Re: LAD 524] #2961524
09/06/21 11:30 AM
09/06/21 11:30 AM
Howell,MI
Moparpoor Offline
Moparpoor  Offline
Howell,MI
VR 1 synthetic
Re: What oil do you use on a solid roller? [Re: Moparpoor] #2961545
09/06/21 12:37 PM
09/06/21 12:37 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Rotella 15w40 with a bottle of Lucas engine oil for 10 years
Re: What oil do you use on a solid roller? [Re: VernMotor] #2961555
09/06/21 01:02 PM
09/06/21 01:02 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Driven 10-40..
Re: What oil do you use on a solid roller? [Re: justinp61] #2961759
09/07/21 06:45 AM
09/07/21 06:45 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have primarily used Rotella.
This was posted by Jason Tabscott on facebook yesterday. He has averaged in the 9.0s on drag week and been 8.9X before with a NA small block. Could just be rumor but I believe he runs near 1" of lift.
Small Block on Drag Week means less than 430" so its not a giant engine.
68 Barracuda Formula S 340
Re: What oil do you use on a solid roller? [Re: Bad340fish] #2961772
09/07/21 08:18 AM
09/07/21 08:18 AM
an8sec70cuda Offline
I ran Mobil One 15w50 synthetic for several years in my hemi w/ no problems at all.
I switched to Valvoline VR1 20w50 conventional oil when the Mobil One got hard to find. Everything still looks great.
I've sent my lifters back to Isky twice for inspection and both time came back w/ a clean bill of health...needed nothing. I bought them new in 2006.
My wedge motor has Crane roller lifters in it and I ran it for about 4 years w/ Mobil One 15w50 synthetic. No problems from that one either.
Both street/strip combos.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: What oil do you use on a solid roller? [Re: an8sec70cuda] #2961836
09/07/21 12:16 PM
09/07/21 12:16 PM
central il.
second 70 Offline
second 70  Offline
central il.
Chip I ran the same Mobil 15w50 synthetic in my hemi. It was labeled as racing oil and did contain 1200p zinc.
Re: What oil do you use on a solid roller? [Re: second 70] #2962116
09/08/21 10:54 AM
09/08/21 10:54 AM
Yep, good stuff. up Only reason I stopped using it was for a while, I couldn't find any on the shelf anywhere.
CHIP
Re: What oil do you use on a solid roller? [Re: an8sec70cuda] #2962120
09/08/21 11:05 AM
09/08/21 11:05 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Torco 10-30 SR1r syn in my small block….
Re: What oil do you use on a solid roller? [Re: J_BODY] #2962132
09/08/21 11:53 AM
09/08/21 11:53 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
