Speedo clip #2961693
09/06/21 09:00 PM
09/06/21 09:00 PM
None
71rm23 Offline OP
71rm23  Offline OP
None
Looking for the clip that is usually spot welded to the under side for the speedo cable (right above torsion bar and exhaust). What to use if one cannot be sourced? Thanks
Re: Speedo clip [Re: 71rm23] #2961706
09/06/21 09:38 PM
09/06/21 09:38 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Zip ties! Those clips (If I'm picturing the correct ones) just hold the speedo cable against the floor/subframe to keep it away from the exhaust. There are zip ties that actually have the tree studs that fit into the original holes.
Re: Speedo clip [Re: poorboy] #2961709
09/06/21 09:43 PM
09/06/21 09:43 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Just responded over on B Bodies
Call AMD
It’s included with there 71 B E Floor Pan
Maybe just maybe they would sell separate ?
Peace Scott
https://www.autometaldirect.com/amd-floor-pan-oe-style-71-74-b-and-e-body-p-817.html
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Speedo clip [Re: poorboy] #2961720
09/06/21 10:18 PM
09/06/21 10:18 PM
None
71rm23 Offline OP
71rm23  Offline OP
None
Thanks!
