G2 Hemi EFI application spark plug #2961247
09/05/21 02:05 PM
09/05/21 02:05 PM
Southington Ct.
turbobitt Offline OP
Southington Ct.
I was wondering if anyone out there has used Brisk silver plugs in there G2 Hemi. I have a 572 Hemi that I recently converted to EFI and would like to change out the Champion Racing C63CX non-projected tip, non resister race plug for something that will be friendlier on the sensitive electronics. Looking at Brisk's website, I think the DR14S would be the best alternative.
https://www.briskracing.com/buy-spa...sk-silver-racing-dr14s-spark-plug-detail
Any opinions or thoughts ?
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: G2 Hemi EFI application spark plug [Re: turbobitt] #2961318
09/05/21 06:43 PM
09/05/21 06:43 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I am running these in my efi Hemi:
https://www.summitracing.com/parts/atl-ar3934
Re: G2 Hemi EFI application spark plug [Re: Dragula] #2961382
09/05/21 09:03 PM
09/05/21 09:03 PM
Southington Ct.
Southington Ct.
I had a set of AR 3935 I installed today but they are more like a direct crossover from the Champion C63CX and are non-resister, Non projected tip.
Allan G.
Re: G2 Hemi EFI application spark plug [Re: turbobitt] #2961431
09/05/21 11:15 PM
09/05/21 11:15 PM
I would not use a spark plug that i had never heard of before today, why would you? shruggy work
I use the Autolite # 3934 race plugs in my 15.0 tp 1 compression bracket motor that I race on E85, E85 doesn't like the colder plugs like the 3933 or 3932 shruggy
How much compression and type of fuel and octane are you trying to fire safely work
Re: G2 Hemi EFI application spark plug [Re: turbobitt] #2961435
09/05/21 11:22 PM
09/05/21 11:22 PM
AndyF Offline
AndyF  Offline
Expensive plugs. Buy a set and try them. I doubt you'll notice any difference over a NGK plug. I use the NGK 6987 for all of the street build EFI engines. The 6987 is an OEM fitment for modern cars so it plays well with electronics and EFI and they only cost around $4 each.
Re: G2 Hemi EFI application spark plug [Re: Cab_Burge] #2961473
09/06/21 08:15 AM
09/06/21 08:15 AM
Southington Ct.
Southington Ct.
The Brisk plugs are really popular among the modern performance EFI crowd and not exactly an unheard of plug, except for maybe the old muscle car community.....
The car is mostly street driven at this point and is a 11:1 compression pump gas engine.
Allan G.
Re: G2 Hemi EFI application spark plug [Re: turbobitt] #2961597
09/06/21 03:04 PM
09/06/21 03:04 PM
On your deal I would use a Champion RN9YC or the smaller body RC9YC up scope
Or the Autolite #3911 non resistor race plug or the resistor #3923 up
