Page 7 of 9 1 2 3 4 5 6 7 8 9
Re: Build share [Re: HardcoreB] #2959469
08/31/21 12:54 PM
08/31/21 12:54 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Originally Posted by HardcoreB
Originally Posted by fbs63
Looks Awesome! Whats your geuss on weight? Mine was 3100 lbs with me in it.
I HOPE less than 3000 WITH me but it's probably going to be nearer your weight Bob. Anyone want to guess??? I have MF tube front/coil overs, light brakes all corners, fglass dash, 2x3 rear clip 4-link and all assoc. brackets anti-roll Dana tube floors glass hood bumpers and decklid, 10gallon cell, Dbl beadlocks 10x33.5 M/T, 40 spline gun-drilled, Std 78 case 12V battery in rear. Tube steering column, ALL windows are lexan .125", 8.50 cert cage, mid-plate, PG trans with JW bell...
I probably weight 150/160ish whistling
Mine is 3009 with me in it, ready to race. I would think you would be lighter
....BAD A$$ STREET CAR.....
Re: Build share [Re: n20mstr] #2959478
08/31/21 01:13 PM
08/31/21 01:13 PM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
Looking great. Glad to see you got it moving under its own power this past weekend. Love to hear what you found with the 7530 box. Cant wait to hear how things go at the track. Best of luck!! Oh yeah mine weighed 3470 with me in it, all steel(except bumbers and hood), all working glass, dana 8.50 MS cage and full interior. Im not exactly the smallest guy either smile
Re: Build share [Re: Al_Alguire] #2959501
08/31/21 01:48 PM
08/31/21 01:48 PM
Shelby Twp. Mi
HardcoreB Offline OP
Shelby Twp. Mi
Thanks again. I tried swapping the polarity and it wouldn't even try to fire, back it went. Once i was able to get into programming...I found nothing (that I would recognize) which would retard the timing UNDER 800 rpm. So i just bumped it forward about 10? deg on the pick-up so i could take it around. I did readjust all RPM limits and i took out the 'start retard' which was only 8* also it looked like it had some downtrack/run retards on a graph (dots) that were about 8* so i moved the dots to 0. I havent checked it since those changes, maybe i did find something? Thanks again Tony! I acually weigh 205 so I'm starting to think it'll be close to where you are because the 4link backhalf is 2x3 and all related junk that i prob wouldnt need if it were ladder-bar. It's gotta be 75lbs heavier that a tube back ladder-bar. I don't think I'll be able to scale it before I do test and it kinda is what it is for now. I really would be curious to know how aggressive i can go anti-squat on this set-up. It's sitting at about 37" and 11"!!! showing 179% antisquat. If i move the lower bar up at the axle it'll put it at 41" and 10" with a.s. being 146%...anyone?
Re: Build share [Re: HardcoreB] #2959815
09/01/21 09:12 AM
09/01/21 09:12 AM
Shelby Twp. Mi
Shelby Twp. Mi
Actually it's at 41" and 11"up...I'm gonna try this for now.
Re: Build share [Re: HardcoreB] #2959823
09/01/21 09:32 AM
09/01/21 09:32 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Looking foraard to seeing you results. Very impressive car and as always great tdch info to chew on.
Re: Build share [Re: Jeremiah] #2959883
09/01/21 12:34 PM
09/01/21 12:34 PM
Las Vegas
Las Vegas
Gotta start somewhere with the 4 link. A thousand options and only a few are right for your car smile I would think thats a bit high and short but would need alot more info really, like HP, SLR, Weight, ride Ht, crank centerline, bar spread blah blah blah Also depends on your goal with the car, ride the bars for the fans or get down the track.
Re: Build share [Re: Al_Alguire] #2959956
09/01/21 03:59 PM
09/01/21 03:59 PM
Shelby Twp. Mi
Shelby Twp. Mi
It isnt much lower than a typical BB A-body in the front with a 26" tire so, 12"? It has about 1* rake towards the front. the cam c/l is about 18/ SLR IS 8.75/ HP750/ weight w/dr. 3000/ bar spread is about 10.5 rear and 6 front. There is a pretty quick lower bar change I will make and that'll get me 46" and 10". Which shows a 131 a.s. I'd like to get down the track fast with minor drama.
Re: Build share [Re: HardcoreB] #2960073
09/01/21 07:36 PM
09/01/21 07:36 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
F'N send it. We want progress updates.
Re: Build share [Re: JERICOGTX] #2960156
09/01/21 10:46 PM
09/01/21 10:46 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Originally Posted by JERICOGTX
Originally Posted by n20mstr
I like these build pics threads....I always steal one or two ideas..LOL
Agreed. Wish more people would share build threads.
x3 alot to be learned in these build threads up Very talented gents here.
Re: Build share [Re: racerx] #2960914
09/04/21 10:52 AM
09/04/21 10:52 AM
Shelby Twp. Mi
Shelby Twp. Mi
Thanks again guys! I had it out last night to shake out any obvious bugs in an undisclosed area laugh with help from Gdemon, Dartin and my wife Michelle and thanks to Al for taking a quick tech call as well. There are a couple vids on Facebook. It seems to be working pretty well! I never drove anything this quick but, I felt pretty comfortable pretty quickly.
Re: Build share [Re: HardcoreB] #2960923
09/04/21 11:04 AM
09/04/21 11:04 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Good to hear you got out. I’m sure after working on it that felt good.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Build share [Re: HardcoreB] #2960949
09/04/21 12:15 PM
09/04/21 12:15 PM
How about a face book link please luck?
Re: Build share [Re: Cab_Burge] #2960977
09/04/21 02:38 PM
09/04/21 02:38 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
That is a very nice piece you've put together! Nice work. It's gonna ride real good!
Wes
"Any fool can know. The point is to understand"
- A. Einstein
Re: Build share [Re: EvilB1Dart] #2961094
09/04/21 11:07 PM
09/04/21 11:07 PM
Shelby Twp. Mi
Shelby Twp. Mi
Thanks!!! It is a labor of love at the moment but, watching the vid with sound does make me happy, lol. Trying to link FB vid
Re: Build share [Re: HardcoreB] #2961095
09/04/21 11:08 PM
09/04/21 11:08 PM
Shelby Twp. Mi
Shelby Twp. Mi
Re: Build share [Re: HardcoreB] #2961097
09/04/21 11:18 PM
09/04/21 11:18 PM
Shelby Twp. Mi
Shelby Twp. Mi
The first vid was my second try. This is my first couldn't get the transbrake working this first among other 'new-guy' bugs.
https://www.facebook.com/100000288188438/videos/667039447601999/
Re: Build share (Vids added) [Re: HardcoreB] #2961098
09/04/21 11:21 PM
09/04/21 11:21 PM
Shelby Twp. Mi
Shelby Twp. Mi
Changed tit les. laugh
Re: Build share (Vids added) [Re: HardcoreB] #2961108
09/04/21 11:54 PM
09/04/21 11:54 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
You might have to make the videos public, I can’t see them and am dying to!
Re: Build share (Vids added) [Re: Blusmbl] #2961146
09/05/21 07:32 AM
09/05/21 07:32 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Sounds great
Doug
Re: Build share [Re: HardcoreB] #2961175
09/05/21 09:58 AM
09/05/21 09:58 AM
Mo.
racerx Offline
racerx  Offline
Mo.
This link not working shruggy
