Re: Removing Lil Red Express decals / stickers
[Re: hemienvy]
#2961009
09/04/21 05:31 PM
09/04/21 05:31 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
Honestly, I don't think you'll be able after 40+ years to remove the decals without damage the paint. Everything depending on the car storaging conditions along its life. Maybe some gasoline could help, but dunno
[Re: Copper Dart]
#2961050
09/04/21 08:35 PM
09/04/21 08:35 PM
Posts: 43,521 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Yes, strip eraser is the best. But you can loosen it up with 3M adhesive remover then the wheel and a plastic scraper to help also. Do a google search for the remover and it will bring up the other tools needed. I used to remove/change decals on the doors of semi tractors and these are what I used. NEVER use a razor blade! BTW, there WILL be a shadow where the old decals were, but they make a perfect template to where the new ones go!
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#2961314
09/05/21 06:38 PM
09/05/21 06:38 PM
Posts: 704 USA
rftroy
USA
Yes, strip eraser is the best. But you can loosen it up with 3M adhesive remover then the wheel and a plastic scraper to help also. Do a google search for the remover and it will bring up the other tools needed. I used to remove/change decals on the doors of semi tractors and these are what I used. NEVER use a razor blade! BTW, there WILL be a shadow where the old decals were, but they make a perfect template to where the new ones go! I agree on all points. This is the best way to do it. Robert
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
