Problems with Stealth 440 source heads.
#296040
04/22/09 08:50 AM
04/22/09 08:50 AM
Posts: 353 Chesterfield, MIch
Cuda67
super street
super street
Chesterfield, MIch
Heard that they have alot of problems. (Can't find head gaskets that fit, need to shim rocker shafts, and poor casting. Made in china.) Sounds like buy cheap get cheap? Which is better open chamber or closed? Which cast iron head is better to over? Should I forget cast and go to Aluminum? 67 383 with 484/284 and 10.5 trw pistons. I'm new to this. Thanks for any help. 10.0-1
Re: Problems with Stealth 440 source heads.
[Re: Cuda67]
#296042
04/22/09 09:06 AM
04/22/09 09:06 AM
Posts: 8,908 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Stock one's don't fit but daskets that do fit are readily available
Mill any head or deck the block and you're likely to have to shim the shafts for proper geometry
poor casting
The first batch had some issues but those were supposedly resolved and the customers taken care of
Made in china
Yeah, so ?!?!?!?
[Re: Cuda67]
#296044
04/22/09 09:11 AM
04/22/09 09:11 AM
Posts: 160 Florida
hemisurfer
My Stealth heads are awesome, needed no more work than a set of Eddy's would. Solid lifter Comp Cam and despite what you read I was able to use the 440 Source springs, just had an inner damper added for 50 bucks .
Had them ported by Modern Cylinder and they now outflow many race heads, and they look stock something no other aluminum head can claim.
Do some homework they are great heads.
Chris
[Re: Stanton]
#296045
04/22/09 09:20 AM
04/22/09 09:20 AM
Posts: 75,089 A Banana Republic near you.
JohnRR
WRONG , machining the decks of either the head OR the block ABSOLUTELY DOES NOT EFFECT ROCKER GEOMETRY .
Using rocker shaft shims to make up for aggressive head/block machining will SCREW UP your rocker to valve tip geometry. The PROPER fix is SHORTER push rods ....
this is assuming the rocker to valve tip geometry was correct to begin with
[Re: JohnRR]
#296046
04/22/09 09:38 AM
04/22/09 09:38 AM
Posts: 5,949 British Columbia
chrisf
British Columbia
What exact piston do you have as there is no such thing as a 10.5 trw piston for a 383 .
also you want closed chamber heads .
all the negatives about the stealths are just unfounded internet rumors .
just checked, its not april fools, is this the new mellower JohnRR we have hear rumors about or just sarcasm?
[Re: Cuda67]
#296049
04/22/09 11:24 AM
04/22/09 11:24 AM
JohnRR
Still ??? do you have the number of the exact piston ? I think we have been thru this , if not it's VERY HARD to get 10.0 compression with a FLAT TOP PISTON in a stock stroke 383.
Is your piston a flat top or a DOME ??? What head are you currently using ?
The chamber on the stealth is 84 cc , you are going to have to cut the heads below 80 cc to even think about getting 10.0 in a 383 if you have flat top pistons .
[Re: JohnRR]
#296050
04/22/09 12:15 PM
04/22/09 12:15 PM
Posts: 160 Florida
hemisurfer
correct I was running a 383 that if I remember right was .010 or .020 in the hole and with a 79.5cc chamber (NHRA stocker spec) it was a little over 10.1 with stock pistons/rods. Head gasket was .035 or .030 compressed.
Chris
[Re: hemisurfer]
#296051
04/22/09 12:44 PM
04/22/09 12:44 PM
JohnRR
Was that a TYPO , to get close to 10.0 the piston needs to be NHRA spec .021 (.020???) ABOVE THE DECK .
[Re: JohnRR]
#296052
04/22/09 01:18 PM
04/22/09 01:18 PM
DaytonaTurbo
Manitoba, Canada
Wow John, thank you. That just made my whole day!
[Re: JohnRR]
#296053
04/22/09 02:27 PM
04/22/09 02:27 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
[Re: Cuda67]
#296055
04/22/09 03:33 PM
04/22/09 03:33 PM
RapidRobert
If it's running now I'd do a compression check that'd give you something for a baseline, if not measure your deck height when you open it up so with the new heads you can plug it all into http://kb-silvolite.com/calc.php? to get your actual CR
[Re: JohnRR]
#296056
04/22/09 05:11 PM
04/22/09 05:11 PM
Posts: 160 Florida
hemisurfer
not a typo it was a true 10-1 down in the hole .010,.020 with 79.5cc chambers NOT ABOVE THE DECK.From the factory chambers were 88cc, closer to 8.2-1 even though advertised at 10.5-1. This was a 70 date coded HP 383 Motor.
Chris
[Re: hemisurfer]
#296057
04/22/09 11:15 PM
04/22/09 11:15 PM
JohnRR
Something does not add up , to get 10.0 with 79.5 cc chamber the piston HAS to be poking above the deck .020ish, below the deck that much the chamber needs to be near 73cc .
