E body subframe connector parking brake holes.
#2959868
09/01/21 11:49 AM
09/01/21 11:49 AM
Posts: 1,184 clarks summit pa
73cuda340
clarks summit pa
Hi, I have the us car tool subframe connectors that are formed to the floor pan for my cuda. Does anybody have a measurement of where the holes need to be drilled for the parking brake cables to pass through? I don't have any cables on my car yet, I'm just trying to prefab everything first. Thanks
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: E body subframe connector parking brake holes.
[Re: stumpy]
#2959901
09/01/21 01:08 PM
09/01/21 01:08 PM
73cuda340
clarks summit pa
The car didn't have any cables on it when I got it, so I wasn't sure which ones were used.
[Re: Neil]
#2960064
09/01/21 07:07 PM
09/01/21 07:07 PM
73cuda340
clarks summit pa
I think your going to want to make the cable pass thru holes after the connectors are installed to get it right. The connectors are welded in now. I was going to start cutting the holes as my next step.
[Re: Neil]
#2960238
09/02/21 09:08 AM
09/02/21 09:08 AM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
I did the same years ago on my dart build
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
[Re: Copper Dart]
#2960553
09/03/21 09:32 AM
09/03/21 09:32 AM
73cuda340
clarks summit pa
Ok. Thanks for all of the pictures from everyone
[Re: A39Coronet]
#2961349
09/05/21 08:06 PM
09/05/21 08:06 PM
Copper Dart
What did you paint the inside of the connectors with, either before or after install? Not sure you were asking me but my I learned long ago that properly applied rustoleum rattle can paint works exceptionally well, just try removing it once its fully cured. Ive used semigloss black everywhere and im very happy with the finish, it does take its sweet time drying though. So yes, i painted the inside of the connectors before welding/install to protect the bare metal. Copper
[Re: Copper Dart]
#2961755
09/07/21 06:04 AM
09/07/21 06:04 AM
Posts: 1,115 Usa
A39Coronet
Usa
What did you paint the inside of the connectors with, either before or after install? Not sure you were asking me but my I learned long ago that properly applied rustoleum rattle can paint works exceptionally well, just try removing it once its fully cured. Ive used semigloss black everywhere and im very happy with the finish, it does take its sweet time drying though. So yes, i painted the inside of the connectors before welding/install to protect the bare metal. Copper Thank you. My plan was to use weldable primer on the edges and then coat with exactly that Rust-Oleum. Car probably won't ever see rain but just wanted to be safe
