What makes a STD or Gilmer belt flup #2959646
08/31/21 07:06 PM
08/31/21 07:06 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Even though it is new and you know it is aligned perfectly.?
Bottom crank pulley is 2.5 inches wide and the belt rides right in the middle.
Re: What makes a STD or Gilmer belt flup [Re: Sammy] #2959650
08/31/21 07:07 PM
08/31/21 07:07 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Detonation
Re: What makes a STD or Gilmer belt flup [Re: FastmOp] #2959798
09/01/21 07:57 AM
09/01/21 07:57 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Originally Posted by FastmOp
Detonation
Don't think this is my problem. Q16 fuel and timing set at 35 degrees.
