Re: Build share
[Re: 440Jim]
#2937670
06/28/21 12:55 PM
06/28/21 12:55 PM
Posts: 4,279 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Good to hear!
Looks like a top quality car/chassis. The 485 CID Indy SR motor will be mild for that car. But you have lots of upgraded parts already on it to make 1000 hp with some heads, etc. Thanks Jim. I already have about 90% of everything I need to RELIABLY upgrade to about 925HP. This is to get acquainted to the car etc.
Re: Build share
[Re: HardcoreB]
#2937672
06/28/21 12:57 PM
06/28/21 12:57 PM
HardcoreB
Shelby Twp. Mi
I've been fixing the bugs successfully all week so it'll be out soon.
Re: Build share
[Re: Jeremiah]
#2937894
06/29/21 07:08 AM
06/29/21 07:08 AM
HardcoreB
Shelby Twp. Mi
Looking good! I dig that insulator between the base and top on the t-ram. I want one! THANKS! I used a piece of 1/2" thick Delrin plastic to add plenum volume. It was hand-made (no bridgeport). With a little engine RTV it's sealed-up tight.
Re: Build share
[Re: HardcoreB]
#2937907
06/29/21 07:51 AM
06/29/21 07:51 AM
Posts: 13,530 Marion, South Carolina [><]
an8sec70cuda
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
Re: Build share
[Re: an8sec70cuda]
#2937979
06/29/21 11:28 AM
06/29/21 11:28 AM
Posts: 19,599 Las Vegas
Al_Alguire
Las Vegas
Looks killer. And yep plenum spacers on that intake are usually needed for most.
Re: Build share
[Re: n20mstr]
#2938010
06/29/21 12:43 PM
06/29/21 12:43 PM
HardcoreB
Shelby Twp. Mi
LOOKS SO NICE
Did you leave stock rad support? for fenders to bolt to? This is ther best pic i could find...I welded thin-wall 1x1 steel for verticle raisers and radiator mount etc. I welded 1x1 angle iron to those for upper core support and fender mounts.
Re: Build share
[Re: fbs63]
#2938022
06/29/21 01:06 PM
06/29/21 01:06 PM
HardcoreB
Shelby Twp. Mi
Looks Awesome! Whats your geuss on weight? Mine was 3100 lbs with me in it. I HOPE less than 3000 WITH me but it's probably going to be nearer your weight Bob. Anyone want to guess??? I have MF tube front/coil overs, light brakes all corners, fglass dash, 2x3 rear clip 4-link and all assoc. brackets anti-roll Dana tube floors glass hood bumpers and decklid, 10gallon cell, Dbl beadlocks 10x33.5 M/T, 40 spline gun-drilled, Std 78 case 12V battery in rear. Tube steering column, ALL windows are lexan .125", 8.50 cert cage, mid-plate, PG trans with JW bell... I probably weight 150/160ish
Re: Build share
[Re: HardcoreB]
#2959369
08/31/21 09:19 AM
08/31/21 09:19 AM
HardcoreB
Shelby Twp. Mi
Four inch OD shaft from Raven required moving the safety loop for clearance.
Re: Build share
[Re: HardcoreB]
#2959393
08/31/21 10:04 AM
08/31/21 10:04 AM
Posts: 8,245 Plymouth, MI
Blusmbl
Plymouth, MI
That thing is a work of art! What track are you taking it to? Lapeer? I think Martin has an open T&T on Friday!
Re: Build share
[Re: Blusmbl]
#2959406
08/31/21 10:37 AM
08/31/21 10:37 AM
HardcoreB
Shelby Twp. Mi
That thing is a work of art! What track are you taking it to? Lapeer? I think Martin has an open T&T on Friday! Thank you! I'm planning on Ubly when I can gather my crew. I only plan to 1/8mi at most....I'll be putting tires on it before I feel safe to run 1/4.
