Page 6 of 9 1 2 3 4 5 6 7 8 9
Re: Build share [Re: n20mstr] #2935256
06/21/21 11:06 AM
06/21/21 11:06 AM
Shelby Twp. Mi
HardcoreB Offline OP
Shelby Twp. Mi
This weekend I finally hit the start button! I had great help from Randy (Dartin) and Shaun Meyers and we got it going. There are a couple vids on FaceB...I'm not sure how to link? It SOUNDS decent anyway. Some of the data display is not working well and I have to finish riveting some tin, and needs front alignment. But it's getting closer to track time!!!
Re: Build share [Re: HardcoreB] #2935264
06/21/21 11:26 AM
06/21/21 11:26 AM
NC
440Jim Offline
440Jim  Offline
NC
Good to hear!
Looks like a top quality car/chassis. The 485 CID Indy SR motor will be mild for that car. But you have lots of upgraded parts already on it to make 1000 hp with some heads, etc.
Re: Build share [Re: 440Jim] #2935454
06/21/21 11:38 PM
06/21/21 11:38 PM
gregsdart Offline
gregsdart  Offline
Lots of great work I see! Waiting for a track day report!
Re: Build share [Re: 440Jim] #2937670
06/28/21 01:55 PM
06/28/21 01:55 PM
Shelby Twp. Mi
Shelby Twp. Mi
Originally Posted by 440Jim
Good to hear!
Thanks Jim. I already have about 90% of everything I need to RELIABLY upgrade to about 925HP. This is to get acquainted to the car etc.
Re: Build share [Re: HardcoreB] #2937672
06/28/21 01:57 PM
06/28/21 01:57 PM
Shelby Twp. Mi
Shelby Twp. Mi
I've been fixing the bugs successfully all week so it'll be out soon.
Re: Build share [Re: HardcoreB] #2937715
06/28/21 04:26 PM
06/28/21 04:26 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Looking good! I dig that insulator between the base and top on the t-ram. I want one!
Re: Build share [Re: Jeremiah] #2937894
06/29/21 08:08 AM
06/29/21 08:08 AM
Shelby Twp. Mi
Shelby Twp. Mi
THANKS!
I used a piece of 1/2" thick Delrin plastic to add plenum volume. It was hand-made (no bridgeport). With a little engine RTV it's sealed-up tight.
Re: Build share [Re: HardcoreB] #2937907
06/29/21 08:51 AM
06/29/21 08:51 AM
an8sec70cuda Offline
Very nice!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Build share [Re: an8sec70cuda] #2937979
06/29/21 12:28 PM
06/29/21 12:28 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Looks killer. And yep plenum spacers on that intake are usually needed for most.
Re: Build share [Re: Al_Alguire] #2937987
06/29/21 12:43 PM
06/29/21 12:43 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
LOOKS SO NICE
Did you leave stock rad support? for fenders to bolt to?
....BAD A$$ STREET CAR.....
Re: Build share [Re: n20mstr] #2938010
06/29/21 01:43 PM
06/29/21 01:43 PM
Shelby Twp. Mi
Shelby Twp. Mi
Originally Posted by n20mstr
LOOKS SO NICE
This is ther best pic i could find...I welded thin-wall 1x1 steel for verticle raisers and radiator mount etc. I welded 1x1 angle iron to those for upper core support and fender mounts.
Re: Build share [Re: HardcoreB] #2938013
06/29/21 01:51 PM
06/29/21 01:51 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Looks Awesome! Whats your geuss on weight? Mine was 3100 lbs with me in it.
Re: Build share [Re: HardcoreB] #2938014
06/29/21 01:51 PM
06/29/21 01:51 PM
Shelby Twp. Mi
Shelby Twp. Mi
LOL...same pic is on page one here but, better quality. I just checked. If you look at some of the other earlier pics in this thread you'll see the 3 pieces of plate that bridge the gap between the grill and the 'new' core support. The middle piece i had edm burn a logo with my initials.
Re: Build share [Re: fbs63] #2938022
06/29/21 02:06 PM
06/29/21 02:06 PM
Shelby Twp. Mi
Shelby Twp. Mi
I HOPE less than 3000 WITH me but it's probably going to be nearer your weight Bob. Anyone want to guess??? I have MF tube front/coil overs, light brakes all corners, fglass dash, 2x3 rear clip 4-link and all assoc. brackets anti-roll Dana tube floors glass hood bumpers and decklid, 10gallon cell, Dbl beadlocks 10x33.5 M/T, 40 spline gun-drilled, Std 78 case 12V battery in rear. Tube steering column, ALL windows are lexan .125", 8.50 cert cage, mid-plate, PG trans with JW bell...
I probably weight 150/160ish whistling
Re: Build share [Re: HardcoreB] #2959365
08/31/21 10:15 AM
08/31/21 10:15 AM
Shelby Twp. Mi
Shelby Twp. Mi
More updates..I finished front/rear alignment, the MF suspension definitely has some inherent bumpsteer issues. Also added some LCA bumpers to the frame. I feel it's safe now but, I'll never buy that same unit here. Tin is done. Had some dig7 Ignition issues hopefully resolved. I added a bleed to the waterpump impeller chamber thanks to a recent post here. Just a bunch of misc fixes after i got it running. I wound up driving it around the block and have made some more mechanical changes since. I plotted the 4-link and it's a little more aggressive than I thought but I'd like the rear to separate. I have a pretty tight valved 5 inch travel shock. So any suggestions would be appreciated. Plan is to take it out for testing this weekend.
Re: Build share [Re: HardcoreB] #2959367
08/31/21 10:18 AM
08/31/21 10:18 AM
Shelby Twp. Mi
Shelby Twp. Mi
Had to flip shock mounts after test drive to raise car and put the shock at a useable height.
Re: Build share [Re: HardcoreB] #2959369
08/31/21 10:19 AM
08/31/21 10:19 AM
Shelby Twp. Mi
Shelby Twp. Mi
Four inch OD shaft from Raven required moving the safety loop for clearance.
Re: Build share [Re: HardcoreB] #2959373
08/31/21 10:23 AM
08/31/21 10:23 AM
Shelby Twp. Mi
Shelby Twp. Mi
Front springs were 250lb 12" I now have 300lb 10". The rear springs are 125lb 10" but it needs 110lb.
Re: Build share [Re: HardcoreB] #2959393
08/31/21 11:04 AM
08/31/21 11:04 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
That thing is a work of art! What track are you taking it to? Lapeer? I think Martin has an open T&T on Friday!
Re: Build share [Re: Blusmbl] #2959406
08/31/21 11:37 AM
08/31/21 11:37 AM
Shelby Twp. Mi
Shelby Twp. Mi
Thank you! I'm planning on Ubly when I can gather my crew. I only plan to 1/8mi at most....I'll be putting tires on it before I feel safe to run 1/4.
