Electronic voltage regulator??? #2959003
08/30/21 12:37 PM
08/30/21 12:37 PM
God's Country Maryland
GODSCOUNTRY340 Offline OP
I've got 4 electronic voltage regulators and they all have different ohm ranges, from 1.35 to 3.75. Question is, which one will show a higher charge to the battery, the lower ohms or higher ohms regulator?
Re: Electronic voltage regulator??? [Re: GODSCOUNTRY340] #2959015
08/30/21 01:17 PM
08/30/21 01:17 PM
Try them and let us know scope wrench up
Re: Electronic voltage regulator??? [Re: GODSCOUNTRY340] #2959021
08/30/21 01:32 PM
08/30/21 01:32 PM
just thinking out loud, the one with lesser ohms (resistance) would flow more. for our basic electronic regs which I thought were the same that does seem like quite a range
Re: Electronic voltage regulator??? [Re: RapidRobert] #2959084
08/30/21 04:53 PM
08/30/21 04:53 PM
IMGTX Offline
IMGTX  Offline
What he said is correct but the resistance will change based on current flow needed to keep the voltage at the prescribed voltage.
When un-powered they may not necessarily have a reading of consequence.
Plug them in and see what you get.
Re: Electronic voltage regulator??? [Re: IMGTX] #2959126
08/30/21 06:46 PM
08/30/21 06:46 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I am struggling with trying to understand what resistance you are measuring and what bearing that has on charging voltage setpoint.
