Re: 255/70/15
[Re: JFChallenger440]
#2958747
08/29/21 05:30 PM
08/29/21 05:30 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
I run those on my 68 Satellite . I use a 8"rim with 4 1/2"BS . 7"rim will be fine , yes a little more bulge . Good size tyre without looking oversize . Great with my 4.10s
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: 255/70/15
#2959109
08/30/21 06:07 PM
08/30/21 06:07 PM
Posts: 608 TN
1DGEMAN
TN
255 70r 15 tires on 15x7 Rallye wheels. No clearance problems at all. Car is an original owner 440 6bbl 4sp numbers matching.
Real Men shift for themselves
Re: 255/70/15
[Re: 1969ronnie]
#2960540
09/03/21 08:47 AM
09/03/21 08:47 AM
Posts: 5,658 Detroit area
6PAX
Detroit area
Hi Moparts , update , I did get my new rear tires in from cooper in the 255-70-15 size , and they are perfect compared to the 275-60-15s i'm replacing . The next question is cooper changed the Font of the white letters VS the old tires . and the new tire letters look bigger and slightly slanted . Here we Go , New White letters out , or Black Side Walls out using American Racing Torque Thrusts Rims mounted on a dark green 1969 Coronet with black vinyl top ? Black walls out would be my choice as I'm not a fan of white letter tires on aftermarket wheels. However, I do prefer white letter tires on factory rally wheels.
Re: 255/70/15
[Re: Belvedere1]
#2960686
09/03/21 03:12 PM
09/03/21 03:12 PM
6PAX
Detroit area
Do you happen to know what the backspace dimensions were on those 15 x 7s? 4 1/8"
