oil pumps #295806
04/21/09 09:57 PM
04/21/09 09:57 PM
usa
hot67cuda Offline OP
usa
A question came up today with some g m friend who thinks his oil pump is cavatating.My question is how oil dose a bb high volume pump produce ??????????.
Re: oil pumps [Re: hot67cuda] #295807
04/21/09 10:00 PM
04/21/09 10:00 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Can you reword that? how many psi? at what rpm?
Re: oil pumps [Re: hot67cuda] #295808
04/21/09 10:01 PM
04/21/09 10:01 PM
usa
usa
How many gal per min
Re: oil pumps [Re: hot67cuda] #295809
04/21/09 10:16 PM
04/21/09 10:16 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
My system one oil pump will flow 30 GPM and will create from 80 PSI to 250 PSI.
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: oil pumps [Re: go green] #295810
04/21/09 11:25 PM
04/21/09 11:25 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Dean,is that at idle or 8k rpm??Milodon advertises 19 GPM.Then one needs the filter that will flow the number. If it is a by-pass style filter,,,,,it will open the by-pass and then nothing is being filtered
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
