70-74 Challenger trunk pan question. #2957978
08/27/21 12:07 PM
08/27/21 12:07 PM
upstate NY
batt2rm Offline OP
batt2rm  Offline OP
upstate NY
Hi,
Is there a difference between a 1970 Challenger 1 piece floor pan and the floor pan in the 71-74 Challenger. I have a 71 Challenger and can get a nice deal on a AMD one piece floor pan that is for a 70. AMD has different part # for the 70 and 71-74. I have looked at other brands they have the same part # for 70-74. Is there a difference? If there is what would the difference be?
Thanks for any help!
Re: 70-74 Challenger trunk pan question. [Re: batt2rm] #2957979
08/27/21 12:14 PM
08/27/21 12:14 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
Yes, the position of the shock access plugs changed. However, that change didn’t occur until sometime in the 1971 production year, so depending on your build date, a 1970 trunk pan might be correct for your car.
My ‘71 Challenger with original sheet metal was built in late October and has the 1970 style trunk pan.
I don’t know when the changeover to the new style floor took place but at least for cars built early in the run a 1970 pan is what is needed.
Re: 70-74 Challenger trunk pan question. [Re: Mastershake340] #2957985
08/27/21 12:31 PM
08/27/21 12:31 PM
upstate NY
batt2rm Offline OP
batt2rm  Offline OP
upstate NY
My build was 3/71
Thanks for the info!!
Re: 70-74 Challenger trunk pan question. [Re: Mastershake340] #2957995
08/27/21 01:12 PM
08/27/21 01:12 PM
upstate NY
batt2rm Offline OP
batt2rm  Offline OP
upstate NY
Did they change the position of the shock mounts in the 71-74 models or just the floor pan holes to make it easy to reach the upper shock bolts?
Re: 70-74 Challenger trunk pan question. [Re: batt2rm] #2957996
08/27/21 01:15 PM
08/27/21 01:15 PM
Philadelphia
The_Blue_Dodge Offline
Philadelphia
Just the floor pan holes.
Re: 70-74 Challenger trunk pan question. [Re: The_Blue_Dodge] #2958204
08/28/21 07:23 AM
08/28/21 07:23 AM
rust belt
Moparite Online content
Moparite  Online Content
rust belt
Quote
You need to be doing 1/4's also to fit it in there. The 2 piece ones are for not replacing the 1/4's.
