Re: Correct Hemi Alternator Pulley ?
[Re: mopar4ya]
#295741
04/21/09 08:36 PM
04/21/09 08:36 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
My understanding is that '68 and earlier didn't use double pulleys. It was a '69 and later thing.. My '68 Dodge Parts book reflects the 426 Hemi didn't have a unique pulley, but my '69 Dodge Parts book DOES show a different and unique alternator pulley. I know this doesn't address your '67 question, but my experience shows survivor '67 hemi-equipped cars had a single pulley. I fell down the road of thinking that all hemi's had double. I learned my lesson early and on the cheap.
Troy
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: hemi68charger]
#295742
04/22/09 08:12 AM
04/22/09 08:12 AM
Posts: 2,655 western PA
mopar4ya
western PA
Maybe I'm trying to track something down that will be wrong on this car. I guessed I need a double pulley based on ones I have seen advertised as being for 66-71 Hemis. Can someone post a picture of an original 67 hemi alternator with the pulley. Thanks Dan
[Re: mopar4ya]
#295743
04/22/09 09:12 AM
04/22/09 09:12 AM
hemi68charger
Houston, Tx
Thanks Dan
That's what happened to me as well with a water pump pulley. Then I realized my '68 needed the standard big block non-a/c version. Ya learn something new everyday..... One source of reliable information are factory parts books. My '68 showed that there wasn't a unique part number for the 426 water pump pulley, it was the same as a 383/440 non-a/c.... Then, I looked in my '69 parts book and low-and-behold, there was a difference for the 426 compared to the 383/440..
Troy
[Re: hemi68charger]
#295745
09/19/09 02:07 PM
09/19/09 02:07 PM
Posts: 75,409 A gulag near you.
JohnRR
A gulag near you.
Thanks Dan
Troy
This is correct , 66-68 hemi used the same pulley on the waterpump as the B/RB wedge motor , the offset of the pulleys changed in 69 , why ?? , that's when the change to the double groove pulley happened .
[Re: az426john]
#295746
09/19/09 02:17 PM
09/19/09 02:17 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
According to Jim Drain who just restored the Judy Lilly car and Frank Badalson it is a single pully on 66 & 67 Hemi cars. Like your shown only single pully
And I'll second that, Jim is correct
[Re: maxie]
#295750
09/20/09 08:59 AM
09/20/09 08:59 AM
JohnRR
A gulag near you.
I have a alternator with a date of 9/68 on it and it has the hemi double groove pulleys on it.
scott
Which would make that a 69 model year part .
[Re: 68jim]
#295755
09/20/09 06:24 PM
09/20/09 06:24 PM
JohnRR
A gulag near you.
The date on mine is 14-68, which I think should be 14th week or early April. It has the 2095059 dual groove pulley. This is from a May built 68 Hemi Runner. However, the original poster is looking for 67 info...
What does your water pump pulley look like ?
