Mechanical fuel pump with a solid roller
#2957375
08/25/21 06:25 PM
08/25/21 06:25 PM
Posts: 1,070 Big Western Pencilveinya
Uncle Barry
My brother and I are about to assemble my hemi and are running a Bullet solid roller. Do you folks have luck with fuel pump pushrods on a solid roller cam core lasting? We have a NASCAR pushrod with the brass end. Thanks for any input 👍
Re: Mechanical fuel pump with a solid roller
[Re: Uncle Barry]
#2957410
08/25/21 07:56 PM
08/25/21 07:56 PM
Posts: 4,733 Moved to N.E. Tennessee
GomangoCuda
check your solid roller cam to see if it has a fuelpump eccentric. Many don't, leaving you no options for a mechanical pump.
[Re: Uncle Barry]
#2957574
08/26/21 11:33 AM
08/26/21 11:33 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I would call the cam company and ask to speak to someone that has worked with those items. If wear is an issue, it might be possible to make another pushrod out of bronze or brass shaft?
[Re: gregsdart]
#2957598
08/26/21 01:08 PM
08/26/21 01:08 PM
Posts: 4,684 Wichita
GY3
Wichita
We used Howards bronze tipped pushrod with our hydraulic roller cam.
Has 7,000+ miles on it and no issues.
