Re: check out this old skool build [Re: cudaman1969] #2956562
08/23/21 12:49 PM
08/23/21 12:49 PM
an8sec70cuda Offline
Originally Posted by cudaman1969
Even in the last ten years one tracks tech line was at the gate, your $25 got you passed. One wreck in 25 years, grudge run and way to much engine, big nitrous and big engine, wasn’t ready for all that, low 4s in the 1/8th. Racers are smart enough today to know what’s not safe, more so than the wanna be big time tech jocky who works at Walmart during the week.
LOL, yep! That thing wouldn't get a second glance at a lot of tracks around here as far as tech goes. It's better than some stuff I've seen run...pretty fast junk too.
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: check out this old skool build [Re: theraif] #2956609
08/23/21 02:13 PM
08/23/21 02:13 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Originally Posted by theraif
Originally Posted by bigdad
Many moons ago, it looked like this .. for the time, it was fast , late 70's it ran 10 oh's .. dipped into the 9's
One day, after a dry hop a 3/4 break bar rolled out of the car at the line
Dick Dyce a one time big time drag racer had it stashed for years , he owned couple large salvage yards, hence the name
no chit i love the look of that car with that scoop ......
The BEST scoop ever imo too! To heck with the fast cars all tucked in and can’t see then need 4 guys just to get you in the right place. Been there done that. I’ll be back to the slow car where you open the door to see if you’re in the water, shut door pull belts tight nail it, the good ole days. No one needed for help. Pump gas too! That is my kinda car right there
Re: check out this old skool build [Re: fast68plymouth] #2956619
08/23/21 03:00 PM
08/23/21 03:00 PM
Almost Heaven
Bob Stinson Offline
Bob Stinson  Offline
Almost Heaven
Originally Posted by fast68plymouth
Looks pretty rust free.
Could probably be brought back to something fairly “normal” with less work than some are doing with pretty rotted out hulks.
I bought an A12 that was hacked up like that by a Vanke's shop back in the day.
Everything and I mean everything on that kind of car is hacked and making something nice out of it is a bigger task than you might think.
69 road runner A12 ex-racer
71 Duster w/ a 400
Shiny paint causes stress.
Re: check out this old skool build [Re: slantzilla] #2956625
08/23/21 03:18 PM
08/23/21 03:18 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Originally Posted by slantzilla
I've been to some "outlaw" tracks where you can still see worse than that running. drive
We race at one track where you hold your signed tech card out the window as they pull you into the burnout box.... shock
'63 Dodge 330
11.19 @ 121 mph
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
Re: check out this old skool build [Re: cudaman1969] #2956626
08/23/21 03:23 PM
08/23/21 03:23 PM
St.Pete,Florida
lancer493 Offline
lancer493  Offline
St.Pete,Florida
Glad to read some of these later responses. My current car is basically old school look all over the outside, but very safety oriented in the rest of the construction. Hoping to create the spiffed up barn-find illusion as a tribute to those good ole earlier days. We went from class and trophy racing to bracket racing to try to perpetuate the sport and make it stay attractive- then along comes technology and throws a monkey wrench into that idea. Back to the bucks and higher skills again.Hobbies need participants to sustain. No electronics and index racing with half second interval steps does seem like it helps to level the playing field, MAYBE a little more focused on more basic human skills. Bill, yup, you guessed it, I'm an old guy!
Re: check out this old skool build [Re: lancer493] #2956643
08/23/21 04:12 PM
08/23/21 04:12 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I'm just amazed that the front end is still "straight" and not bent up to the sky. Removing the inner fenders takes all the structural integrity away and I don't see any front stringers from the roll bar/cage.
Re: check out this old skool build [Re: 70HemiGTX] #2956656
08/23/21 04:33 PM
08/23/21 04:33 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Funny how they cut the inner fenders out in the effort to save weight but the super heavy drum brakes are still there!
'63 Dodge 330
11.19 @ 121 mph
Re: check out this old skool build [Re: GY3] #2957121
08/24/21 11:19 PM
08/24/21 11:19 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I was told that a lot of the Stock Eliminator guys rans drum brakes all round, as they had less drag?
Alan Jones
Re: check out this old skool build [Re: LA360] #2957227
08/25/21 11:14 AM
08/25/21 11:14 AM
The drum brakes are lighter than the factory disc brakes too. Aftermarket brakes are a different story.
CHIP
Re: check out this old skool build [Re: an8sec70cuda] #2957232
08/25/21 11:30 AM
08/25/21 11:30 AM
Denver, CO
BigBlockGTS Offline
BigBlockGTS  Offline
Denver, CO
"The drum brakes are lighter than the factory disc brakes too. Aftermarket brakes are a different story."
I have been told the same thing. They also could be adjusted for zero drag as noted above.
Re: check out this old skool build [Re: BigBlockGTS] #2957291
08/25/21 01:51 PM
08/25/21 01:51 PM
moparx Offline
moparx  Offline
the zero drag was the deciding factor with using drum brakes, but was somewhat scary stopping at the big end, depending on your top speed.
i tried that back in the early 70's, and i didn't like the stopping power vs the few hundredths gained, so i adjusted them back up. biggrin
beer
Re: check out this old skool build [Re: moparx] #2957303
08/25/21 02:28 PM
08/25/21 02:28 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I get the whole "zero drag" thing, but even back then there were lightweight aftermarket alternatives.
25 lbs. per corner on the front is a lot to give up!
'63 Dodge 330
11.19 @ 121 mph
Re: check out this old skool build [Re: GY3] #2957352
08/25/21 05:17 PM
08/25/21 05:17 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
The 9” drums on the front of the Duster are almost the same weight as the aftermarket disc. I know the disc stop better but at 120 on a 1/4 track its still easy to stop in plenty of time
Re: check out this old skool build [Re: GY3] #2957353
08/25/21 05:18 PM
08/25/21 05:18 PM
lino lakes, mn
Schultz62 Offline
Schultz62  Offline
lino lakes, mn
GY3 the key word is 'aftermarket'. A gent back then would not consider paying for any upgrade that didn't include horsepower. Brakes? leave them and just hope it will stop after 1320 and backing them off to have less rolling resistance. This car is a time capsule. Is it unsafe in people's minds now?... yes absolutely. The people saying they see the same type of stuff today that runs at tracks shows 'it aint pretty, and it's probably unsafe but it's what I have and I will try and make a few hits' Would I want to run next to that car?...No! The thing for me is the nostalgia. It's cool and brings me back many years ago.
Re: check out this old skool build [Re: Schultz62] #2957363
08/25/21 06:00 PM
08/25/21 06:00 PM
St.Pete,Florida
lancer493 Offline
lancer493  Offline
St.Pete,Florida
Yes, things happened differently at the dragstrip in the early 70's. Some scary things were raced by todays standards.I raced a 3200lb big block Nova, high 9's 140mph. It had 6cyl drum brakes w/metallic linings up front, with big Mopar drum brakes w/ organic linings in the rear. Thought it was the best of both worlds. Cheap, light and stopping was never a problem. No internet then to bounce around ideas and reviews of performance parts, just word of mouth and car magazines. Most stuff was put together with a large helping of used parts. You had to "TRY"stuff, money was spent trying to go fast. Most guys didn't have the money for the cylinder heads and work that it took for the horsepower of today.If it didn't make the car go faster ,it didn't get bought. If you wanted a real safe car, you borrowed Mom's. Hope that sheds some light for those not old enough to remember. The 9sec big block was all iron and all used parts except rings, bearings,gaskets, and a roller cam bought with an IRS refund. You can go fast on a budget, its just not as pretty. Bill
Re: check out this old skool build [Re: lancer493] #2957374
08/25/21 06:25 PM
08/25/21 06:25 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Love the stock 10" drum brakes too, I would send it! boogie
JB Rhinehart, Realist
A-Body's RULE!
Re: check out this old skool build [Re: Rhinodart] #2957382
08/25/21 06:47 PM
08/25/21 06:47 PM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
Hell , back quite a few years ago . I had a 66 Dart with a pretty warm 440 in it Dana out back with big drums and small 6cyl drum brakes on the front. Talk about and Eticket ride on the binders at a short shutdown track. It went .10.60s back then and 128.or so mph , No way I would do that now but it was cheap and I was bullet proof. LOL
6.50 @105.26
Re: check out this old skool build [Re: lancer493] #2957729
08/26/21 06:51 PM
08/26/21 06:51 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Almost had forgot about those metallic brake shoes. Back then when we where racing none of that other stuff mattered. Now it’s everybody’s obsession, like the street cars today. Big radio, big tires, nine shocks for each wheel, power steering, calipers the size of suitcases and don’t forget the AC blowing cold. Truth be known that car is as safe as a small tire 1800 HP turbo-nitrous car today.
Re: check out this old skool build [Re: cudaman1969] #2957731
08/26/21 07:01 PM
08/26/21 07:01 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Looks like one of my hack jobs from the 70's. Wouldn't mind having it in the fleet now..... drive
