4speed: Overcenter spring disconnected
#2957177
08/25/21 08:17 AM
08/25/21 08:17 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Hello all..
Won't pretend to be a 4speed guru.. So, asking here... What is the consequences of the overcenter spring in the pedal assembly NOT being in place. In th past when I have installed a Centerforce clutch, it was instructed to disconnect/remove the overcenter spring. Just noticed on this '70 Charger R/T 4speed car I'm working on that the spring is disconnected AND the car has the original style 3-finger clutch, which means the overcenter spring should be installed and used. What are the consequences of the spring not being installed when a OEM-style 3-fork clutch is used? The clutch pedal really has to be pressed all the way down for me to go through the gears.
Thanks.. Troy
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: 4speed: Overcenter spring disconnected
[Re: Cab_Burge]
#2957222
08/25/21 11:02 AM
08/25/21 11:02 AM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
IIRC, I remember reading early chrysler tech bulletins (1978-2005) about over center springs on later model front wheel drive cars. One of the issues was noise caused when the spring softened over time. As i understood it, it helps with both fully depressed pedal and foot off pedal the same. Please dont rely on my wonderful memory, I dont either. Copper
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
