Page 5 of 5 1 2 3 4 5
Re: 1976 Charger - Speedometer and Gauge Issues [Re: moparx] #2955627
08/20/21 11:10 AM
08/20/21 11:10 AM
RWG75
RWG75
"accessory title lamp" means rear defrost switch light. switch and wire to glass comes with glass.
blue w/ white trace is CI-33, zone 97C, power feed to options not installed: windows, rear defrost, tailgate. body harness comes with option.
hard to tell where they're hanging from the zoom level.
Re: 1976 Charger - Speedometer and Gauge Issues [Re: ] #2956998
08/24/21 04:42 PM
08/24/21 04:42 PM
here.
Remy-Z Offline OP
Remy-Z  Offline OP
here.
I have the cluster back together for the time being, as the Charger needs to be back on the road for the next month or so. Measuring at the gauge input points sees power pulses at or under 5 volts, so for now, I'm focusing on getting this thing moving again. MoParty is too close to keep the car down, and I want to drive it for a bit before the winter hits. Once I get the fuel system mods finished up and have the car running again, I'll update with results. Thank you all for your help!
