Windshield washer pump question #2956916
08/24/21 12:14 PM
08/24/21 12:14 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Does anyone know if all cars that came equipped with a 2-speed wiper motor (A-bodies in particular) came with foot pump windshield washers or was it possible to get an electric pump with 2-speed wipers?
Re: Windshield washer pump question [Re: 6PAX] #2957194
08/25/21 09:38 AM
08/25/21 09:38 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
73 Dart we had was 2 speed and electric pump.We goit it like 40 years ago and was all oe.Still might have the washer around somewhere.Rocky
Chrysler Firepower
Re: Windshield washer pump question [Re: therocks] #2957223
08/25/21 11:04 AM
08/25/21 11:04 AM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
My 1971 Dart Swinger had the two speed motor with foot pump.
I think my 1970 Swinger has the same setup too.
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Windshield washer pump question [Re: Copper Dart] #2957230
08/25/21 11:29 AM
08/25/21 11:29 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
as far I know on A bodies:
up to 72 all 2 speeds were foot operated and 3 speeds/variable with electric pump
73/74, the electric pump was optional with 2 speeds ( foot pump still standard ) and standard with 3 speeds
75/76, the electric pump was standard on all 2 and 3 speeds
On B bodies...
Up to 72 foot operated with 2 speeds standard but electric pump optional ( I can be wrong on this, but I have known of some Charger 71 being foot operated ). 3 speeds/variable electric pump standard.
since 73, all electric pump.
If I'm wrong on the foot pump feature at least for 71/72, then all were electric
Re: Windshield washer pump question [Re: NachoRT74] #2957245
08/25/21 12:19 PM
08/25/21 12:19 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
The reason I asked is I'm in the process of putting my 69 Dart back together and it was a 2-speed/foot pump set-up. I want to keep the 2-speed wipers but I'd like to change it to the electric pump. Would I have to get a later model 2 speed wiper motor and dash switch to convert mine? I already have a washer fluid jar with an electric pump on it.
Re: Windshield washer pump question [Re: 6PAX] #2957397
08/25/21 07:32 PM
08/25/21 07:32 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I would contact one of the wiper motor restoration people. They would be the ones to know what motor/switch combination you'd need to make it all work. twocents
Re: Windshield washer pump question [Re: 6PAX] #2957513
08/26/21 03:31 AM
08/26/21 03:31 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
A friend I was helping on his resto with a 74 and foot pump washer wanted the same, and I replaced the switch from a 76 donor. Just run the extra wire from wiper switch throught bulkhead up to the pump. However being a 74 add on with a 76 piece is easy because the cluster is the same. Dunno on 69 which different cluster, if they are the same switch or fit the same from later models.
You could allways add an extra divorced push in button/switch somewhere on dash/cluster like B Bodies got from factory up to 70, to operate the washer. The power source could be taken from one of the wires at the switch itself to make it operative just when wipers are on, or from some accesories source around and will be operative even with wipers off.
The push in switch could be even foot operated like factory, installed on same foot pump bracket, using one of those big aftermarket generic horn switches
Re: Windshield washer pump question [Re: NachoRT74] #2957515
08/26/21 03:49 AM
08/26/21 03:49 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Like this
It even gets a dust boot. Dunno its size but several options around. Maybe even fits into the foot pump bracket hole.
Editing
The image is from eBay UK and went to the auction but I guess there must be something similar in USA. The hole required for it is around an inch. I think pretty much close to the original foot pump bracket hole? Can't recall.
https://www.ebay.co.uk/itm/111036581499
