Speedometer Repair #2956824
08/24/21 07:26 AM
08/24/21 07:26 AM
Kentucky USA
RR6BBL1969 Offline OP
Kentucky USA
Who does speedometer repair? Everything in it is fine but it reads slower than actual speed.
Re: Speedometer Repair [Re: RR6BBL1969] #2956846
08/24/21 09:23 AM
08/24/21 09:23 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Are you sure you have the correct speedo gear in transmission base on rear end gear? If you have changed tire size from stock size this will also have an effect.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Speedometer Repair [Re: 70gtx440dana] #2956868
08/24/21 09:59 AM
08/24/21 09:59 AM
Kentucky USA
Kentucky USA
Yes, only had 26k miles, stock wheels and tires, unmolested original farm Jeep, new speedometer cable, speedometer reads 0 when doing 5-10, 20-30 when doing 50. This is a 1978 Jeep CJ5 and they were notorious for speedometer and gauge issues.
Re: Speedometer Repair [Re: RR6BBL1969] #2958132
08/27/21 10:23 PM
08/27/21 10:23 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
Old Mechanical speedometers have magnets in them. Over time they loose magnetism. The magnets need to be recharged then the strength adjusted / dialed in to the proper speed. My advice is to call around to speedometer repair shops for just this service. Should be cheep because they dont have to take apart and replace parts.
Re: Speedometer Repair [Re: convx4] #2958184
08/28/21 03:40 AM
08/28/21 03:40 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
That's EXACTLY what he is asking for
whistling
Re: Speedometer Repair [Re: NachoRT74] #2958205
08/28/21 07:38 AM
08/28/21 07:38 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Is the odometer accurate? If yes, then the speedometer needs remagnetized or just a simple clean and lube.
If the odometer is off too, you need to look at the drive gear ratio. Might be a small gearbox on the side of the transfer case.
Angry white pureblood male
Re: Speedometer Repair [Re: ruderunner] #2958313
08/28/21 12:45 PM
08/28/21 12:45 PM
S E Michigan
E
ekim Offline
ekim  Offline
E
S E Michigan
https://www.bobsspeedometer.com/
never used them but its the only one i have heard of
