door plastic water shed #2956428
08/22/21 09:12 PM
08/22/21 09:12 PM
delhi,il
trw1982 Offline OP
trw1982  Offline OP
delhi,il
what are you using? trash bag is too thin. original parts are not avail. need an idea. tia.
Re: door plastic water shed [Re: trw1982] #2956432
08/22/21 09:52 PM
08/22/21 09:52 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
IIRC, I went to Home Depot and picked up a package (lifetime supply) of 6 mil vapor barrier for use under concrete slabs. Seems like it's just a bit heavier than OEM?
lifetime supply vapor barrier linky
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: door plastic water shed [Re: 3hundred] #2956435
08/22/21 10:07 PM
08/22/21 10:07 PM
delhi,il
trw1982 Offline OP
trw1982  Offline OP
delhi,il
thank you.
Re: door plastic water shed [Re: trw1982] #2956453
08/23/21 12:16 AM
08/23/21 12:16 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Re: door plastic water shed [Re: 6PakBee] #2956675
08/23/21 05:54 PM
08/23/21 05:54 PM
5thAve Offline
5thAve  Offline
X2 on the vapour barier from Home Depot. A roll is cheap and I use it for all sorts of stuff like tarping things off from weather etc.
3M spray adhesive works great for holding it on the door.
