Back spacing on 15x10 Cragars #2955599
08/20/21 09:27 AM
08/20/21 09:27 AM
Elizabethtown, KY
6T9Hemi Offline OP
6T9Hemi  Offline OP
Elizabethtown, KY
What is the correct back spacing needed on a 15x10 Cragar on a 69 Road Runner.
1969 340 4 Speed Swinger R4,
black vinyl, white butt stripe, 3:91
Re: Back spacing on 15x10 Cragars [Re: 6T9Hemi] #2955624
08/20/21 11:00 AM
08/20/21 11:00 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Last I heard, 5.5" works on a 15x10 for that application.
That assumes stock & original everything.
I'd sure measure the heck out of the car and existing wheel/tire fit - both sides.
Re: Back spacing on 15x10 Cragars [Re: 6T9Hemi] #2955643
08/20/21 12:14 PM
08/20/21 12:14 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
You really do need to measure as any tire that is an appropriate size for a 10 wheel is going to be very close even if it is perfectly centered between the spring and the wheel opening lip. What size tire? Do you know what the section width is when mounted on a 10" wheel? Also you should measure both sides of the car as it is not unusual for the rear end to be off-center some. You may need to correct that to maximize tire clearance.
Re: Back spacing on 15x10 Cragars [Re: GomangoCuda] #2955988
08/21/21 01:39 PM
08/21/21 01:39 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
most of the wheels are only avail in 3.5 or less backspace anymore... i was trying to use them on my 70 challenger and had to go with the 15x8 instead... which was 4.25 BS iirc... keystone mag
Re: Back spacing on 15x10 Cragars [Re: ph23vo] #2956017
08/21/21 03:19 PM
08/21/21 03:19 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Did they ever come with a 7.25" backspace (for A-bodies)? work
Re: Back spacing on 15x10 Cragars [Re: DrCharles] #2956157
08/21/21 10:32 PM
08/21/21 10:32 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
5-1/2 BS is what you need.
Re: Back spacing on 15x10 Cragars [Re: Stanton] #2956158
08/21/21 10:33 PM
08/21/21 10:33 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
BS !!
Re: Back spacing on 15x10 Cragars [Re: Stanton] #2956195
08/22/21 04:03 AM
08/22/21 04:03 AM
GomangoCuda Offline
GomangoCuda  Offline
Agree but the Crager catalog only shows 3 3/4 and 4 1/4 BS in 10".
Crager used to have a custom shop but it closed.
What I used to do many years ago is buy the 15x7 reversed which.comes with 2 1/4 BS.
I would take them to a local circle track shop and have 3" added to the back side
resulting in 15x10 with 5 1/4 BS. Close enough.
Re: Back spacing on 15x10 Cragars [Re: GomangoCuda] #2956221
08/22/21 09:54 AM
08/22/21 09:54 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
What Cragar sells is not my problem. The question was "what BS for a 10" wheel on a '69 RR" and the answer is 5-1/2"
Re: Back spacing on 15x10 Cragars [Re: Stanton] #2956226
08/22/21 10:17 AM
08/22/21 10:17 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
On my 68 Charger, if I had a 5.5 BS it would hit on the inner wheel tub when turning, I have 15x10 4 7/8 BS 325/50/15 & it just barley rubs the inner on a sharp incline turning, stock width S60, on a big bump the tire will just graze the outer tub hump, I should have removed that B body hump, when it does hit there is NO mark on the tire,
Re: Back spacing on 15x10 Cragars [Re: Stanton] #2956234
08/22/21 10:57 AM
08/22/21 10:57 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Perhaps, but Cragar was a condition of the original question that you chose to ignore:
Now there are numerous Cragar offerings and perhaps they have a style of wheel with the required backspace. However, If we are discussing the venerable SS , which is popular on this era of car, this combination of requirements cannot be met.
Re: Back spacing on 15x10 Cragars [Re: TC@HP2] #2956318
08/22/21 01:43 PM
08/22/21 01:43 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
Don't be an idiot. Regardless of the wheel manufacturer and whether or not they make it, the required backspace doesn't change. It's 5-1/2"
Re: Back spacing on 15x10 Cragars [Re: Stanton] #2956323
08/22/21 01:55 PM
08/22/21 01:55 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
On my 70 Charger, I'm using Magnum 500 15x10 with a 5" backspace. 295/50/15 Dana 60. Fits perfect.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Back spacing on 15x10 Cragars [Re: 6T9Hemi] #2956361
08/22/21 03:43 PM
08/22/21 03:43 PM
GomangoCuda Offline
GomangoCuda  Offline
Original post
With a stock width rearend a 5 to 5 1/2" BS is needed but not available from Cragar. My previous post explained the only way to get there with a Cragar. To be clear on the 69 B body that I did this on it fit better than the 5 1/2 BS aluminum wheels that were put on at a later date which needed 1/4" spacers to get the tire (295/65-15 M/T) further from the spring. A smaller tire might not need a spacer with a 5 1/2 BS.
I have done this same mod with chrome reverse wheels and Keystones.
Way back in the mid 70's I used the same method to widen 8" Cragars for a 70 B body that was mini tubbed and springs moved into the frame rails.
