Re: What 9” center section?
[Re: Alaskan_TA]
#2956139
08/21/21 10:05 PM
08/21/21 10:05 PM
Posts: 10,021 MN
JERICOGTX
MN
HEMI Joel has a complete Moser aluminum center section in his HEMI Coupe. 10 bolt front pinion support. If I was to switch to a 9”, that is what I’d get. Very nice piece.
69 GTX
68 Road Runner
[Re: Pacnorthcuda]
#2956146
08/21/21 10:20 PM
08/21/21 10:20 PM
Posts: 11,531 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Stock 9" stuff is nothing to get excited about. Aftermarket stuff needed for all but the mildest application.
How fancy and/or expensive depends on what you are going to do with it.
[Re: J_BODY]
#2956148
08/21/21 10:22 PM
08/21/21 10:22 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
I guess it all depends on you weight, power, and traction. Light car under 3000# a cast aluminum carrier would live with an automatic foot brake car. Heavy car with good traction will need a billet or iron case. Strange or MW make some good cases and there are many new castings made overseas for about half the price of the American made stuff. I have set up a few Yukon carriers and they are machined "okay" but they need to be de-burred and cleaned up more than a name brand American unit. 9-10 second car I would use a Strange iron case with large bore with 35 spline axles and make sure to use a Daytona pinion support. The Strange ultra 9 1/2" case will handle a ton of abuse as well as some of the billet units from Tom's and a few others in the all out race price range. That said I built a factory nodular case with some good parts 20 years ago and it's still going strong in a low 9 second Camaro Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: J_BODY]
#2956154
08/21/21 10:29 PM
08/21/21 10:29 PM
Posts: 30,998 Oregon
AndyF
Just call Cass and tell him that you want the same thing I got.
[Re: J_BODY]
#2956499
08/23/21 09:30 AM
08/23/21 09:30 AM
Posts: 4,673 On the parachute mount
n20mstr
Any chance you weighed that Andy? Like I said we stopped the 8.75 bleeding long ago and went the “dumptruck” rear option (S-60… also from the good Dr). Even our high 9 combo was twisting up axles pretty good. Having had been around a couple 8.75 failures which in turn destroyed two transmissions, we stepped up. We’re currently running a set of 4.56 gears that we’ve put on well over 250 passes…. and they were used from a friend. If I were to be at that crossroad today I’d be going the 9” route. Prob just from a parts availability standpoint. Just never see the conversation on which parts are required for success. WOW .... PRETTY TRUE !!! LMAO they going to crucify you now Anyway...i have used strange iron housings and even the "lightweight" low hp alum case (non bolt thru) Currently im using a Mark Williams Pro stock center. Alum bolt thru with alum spool and yoke and lightened ring gear. Have had good results (no failures0 with any so far
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2956556
08/23/21 12:36 PM
08/23/21 12:36 PM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
The ONLY factory ford 9" part you can use is the axle housing and even that needs a backbrace welded on. The stock 9" centersections are weak, unless you have one of the factory Hi-perf nodular ones, but those still need the good pinion support.
Years ago I was building a backhalved Duster w/ ladder bars and a 9" rear. I had a complete Moser iron centersection w/ a spool and 35 spline axles. The centersection alone cost $1300 and that was back in 2006 or so.
