how to deal with PEELING CLEAR COAT #2955991
08/21/21 01:43 PM
08/21/21 01:43 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
the roof of my truck suddenly SHED its skin ... do i need to just sand all the clear off ,,,or take all the paint down also?..
i want to just paint the roof area solid white... [from the metallic red it has now].. since i will be going back to the desert sw in the next year or so..
Re: how to deal with PEELING CLEAR COAT [Re: ph23vo] #2956004
08/21/21 02:22 PM
08/21/21 02:22 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Check to see if the color coat is also peeling.
I'd grab a DA & some 180 and sand as evenly as possible into the original primer.
For chipped/scratched panel, likely to bare metal.
If that presents a good surface, clean, prime & paint.
A single-stage paint will save you money & time if you can get a clean enough job.
Re: how to deal with PEELING CLEAR COAT [Re: topside] #2956028
08/21/21 04:02 PM
08/21/21 04:02 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I've talked to my local body shop about spot repairs in BC/CC. If the CC is sound, they scuff the entire panel, do the repair, BC the repair area and then CC the entire panel. But in your case, wow. The majority of the thickness is in the CC. If it's failing, trying to completely remove the CC without damaging the BC would take a better man than me. I'm with Topside, strip it all and go back with single stage.
It amazes me that after all these years and all the glorious reviews of how good BC/CC is over single stage, I still see vehicles with peeling CC.
Re: how to deal with PEELING CLEAR COAT [Re: ph23vo] #2956060
08/21/21 05:38 PM
08/21/21 05:38 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Re: how to deal with PEELING CLEAR COAT [Re: Fat_Mike] #2956064
08/21/21 05:41 PM
08/21/21 05:41 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
Originally Posted by Fat_Mike
yes.. mine has no clear coat that i could spray over now... so it looks like sand it and redo it all...
Re: how to deal with PEELING CLEAR COAT [Re: ph23vo] #2956135
08/21/21 09:45 PM
08/21/21 09:45 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
What year is your truck?
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: how to deal with PEELING CLEAR COAT [Re: ph23vo] #2956274
08/22/21 12:37 PM
08/22/21 12:37 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
My 98 Ram did the same thing. Once the clear starts to lift, it is best to prep the top and respray with either BC/CC or single stage. Luckily it is the top so color matching isn't as important. P.S. I did the front windshield pillars and the body line around the back to minimize the color difference.
My Monster are real!
Living within your means makes life pretty easy.
Re: how to deal with PEELING CLEAR COAT [Re: BloFish] #2956276
08/22/21 12:37 PM
08/22/21 12:37 PM
rust belt
Moparite Offline
Moparite  Offline
rust belt
How about posting some pics! Not one pic posted in this thread or the link.
Re: how to deal with PEELING CLEAR COAT [Re: BloFish] #2956381
08/22/21 05:05 PM
08/22/21 05:05 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
its a 1996 f 250 steve..
Re: how to deal with PEELING CLEAR COAT [Re: ph23vo] #2956382
08/22/21 05:29 PM
08/22/21 05:29 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
My 2006 began to peel the clear coat on the roof and hood, and the only way to fix it was to repaint it down
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: how to deal with PEELING CLEAR COAT [Re: ph23vo] #2956670
08/23/21 05:29 PM
08/23/21 05:29 PM
North Texas
TheTieWrapKid Offline
North Texas
My 2001 Dodge Ram pickup red paint is hanging in there, but the camper top has been peeling clear coat for a couple of years. I've been watching it trying to decide what to do. Maybe the clear coat will come the rest of the way off and I can scuff up and shoot some clear back over it. But that base coat is looking pretty dirty. It will probably need sanding priming and either single stage urethane, single stage urethane and clear, or basecoat / clearcoat urethane. I haven't done much bodywork lately and I need to finish up my Duster and paint it. Maybe I'll try to find a cheap bodyshop to prep and single stage it.
The truck I mean.
drinking
