How to tell what Hemi mounts I have #2954803
08/17/21 06:45 PM
08/17/21 06:45 PM
California
slowfab Offline OP
slowfab  Offline OP
California
I got these 426 hemi mounts but not sure what chassis they fit. Any help would be great.
Re: How to tell what Hemi mounts I have [Re: slowfab] #2954881
08/17/21 09:56 PM
08/17/21 09:56 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
they look to be 64-65 hemi mounts. motor sits lower and farther forward than 66 and up.
Re: How to tell what Hemi mounts I have [Re: old_racer] #2955120
08/18/21 06:43 PM
08/18/21 06:43 PM
California
slowfab Offline OP
slowfab  Offline OP
California
I was thinking they were 66 and up as the one side has some offset to it unlike the 65-66. 🤷‍♂️
Re: How to tell what Hemi mounts I [Re: slowfab] #2955236
08/19/21 07:22 AM
08/19/21 07:22 AM
robertop Offline
robertop  Offline
The orange one sure looks like the one for the passenger side in my 69 roadrunner, I am not sure about the other one. Is it a stock item or a reproduction? Some angles don' t look right, too sharp for an original mount. My 2 cents.a
Re: How to tell what Hemi mounts I [Re: robertop] #2955311
08/19/21 01:16 PM
08/19/21 01:16 PM
moparx Online content
moparx  Online Content
it also looks like it may be made of a slightly thicker material.
the sharp angles look to be sheared from plate steel.
beer
Re: How to tell what Hemi mounts I [Re: moparx] #2955338
08/19/21 02:25 PM
08/19/21 02:25 PM
California
slowfab Offline OP
slowfab  Offline OP
California
The bare steel one is definitely a re-pop and the orange one I am not sure.
Re: How to tell what Hemi mounts I [Re: slowfab] #2955361
08/19/21 03:27 PM
08/19/21 03:27 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Check with Al Debevic. It almost looks like the one he makes, he can definitely identify them. The other looks original.
Al Debevec 715-267-7141
https://www.forabodiesonly.com/mopar/threads/al-debevec-k-member-mods.427818/
Re: How to tell what Hemi mounts I [Re: Cuda340] #2955816
08/20/21 09:26 PM
08/20/21 09:26 PM
California
slowfab Offline OP
slowfab  Offline OP
California
Thanks, I will ask him
Re: How to tell what Hemi mounts I [Re: slowfab] #2955840
08/20/21 10:37 PM
08/20/21 10:37 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I have mine off I’ll look (68)
Re: How to tell what Hemi mounts I [Re: cudaman1969] #2955851
08/20/21 11:15 PM
08/20/21 11:15 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
1968 mounts
C530C687-2F29-4EA1-A221-875DB440FA6E.jpeg51548854-5F2E-43A4-A6D5-C4F12672E216.jpeg68CE4EFE-4462-4C55-933E-1EC5066A8F9C.jpeg
Re: How to tell what Hemi mounts I [Re: cudaman1969] #2955853
08/20/21 11:19 PM
08/20/21 11:19 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
More pics
Re: How to tell what Hemi mounts I [Re: cudaman1969] #2955879
08/21/21 01:33 AM
08/21/21 01:33 AM
California
slowfab Offline OP
slowfab  Offline OP
California
Thanks, these do look to be the same as the ones I have. Thanks for posting your pics.
Re: How to tell what Hemi mounts I [Re: slowfab] #2955904
08/21/21 09:35 AM
08/21/21 09:35 AM
VA
dragon slayer Offline
VA
You can't tell by picture the difference between B body and 70up E body mounts. You have to do a measurement. Al, can walk you through it. But basically for the Passenger side mount run a straight edge across the bottom edge of the two engine side holes with the insulator side on a flat table. Measure the height of the straight edge. 2 1/2" is B, 2 1/4" is E body.
For the driver side place a large drill bit through the engine side hole that goes closest to the insulator hole on the bottom. Going from center of drill bit to center of the insulator hole a B body gap is 5/8" and the E body is 7/8". I also believe Al use a measurement of the side gap.
Basically a subtle difference between an E and B body.
66-67B bracket had square cut corners and 68 and up B has rounder corners.
