Does anyone know what the proper placement is for the 3 point emblem (I can't think of the correct name for this) that is located behind the rear side window of a 69 Coronet?
Here is a picture of what I'm talking about.
Thanks,
Yes, fratzog is correct. And I do have some measurements for it. A member on a different forum had asked the same thing, so I already had this photo with dimensions set up. This is from my '69 R/T, still has original vinyl top so I don't believe the fratzog has been off the car since the factory. Hope this helps!
