Clutch question #2955564
08/20/21 06:44 AM
08/20/21 06:44 AM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
I took my car (340/4 spd.) out for a drive yesterday (about 14 miles round trip). When returning home I got about a block from my house and when I let up the clutch pedal in first gear there was a slight grinding sound. I pushed the clutch pedal down and let it up again and there was no grind sound. I pulled in my driveway and was sitting still waiting for the garage door to open. Once opened, I let the pedal up to pull in the garage and heard the grinding sound again. Again I pushed the pedal down and let it up again and no grinding sound. I did this a couple more times and the results were the same, sometimes the grind sound but most of the time not. I'm not that knowledgeable when it comes to clutches so my question is, is this possibly some sort of adjustment issue or is the clutch going bad?
Re: Clutch question [Re: 1970RT] #2955571
08/20/21 07:23 AM
08/20/21 07:23 AM
VA
dragon slayer Offline
VA
If you are sure you are in gear fully, then something is not right and you need to at least drop the inspection cover and inspect.
Re: Clutch question [Re: 1970RT] #2955598
08/20/21 09:26 AM
08/20/21 09:26 AM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
You can try adjusting first of course cause it's free. Based on my previous luck, it's usually time for syncros/sliders. Hopefully not in your case.
Re: Clutch question [Re: 80fbody] #2955600
08/20/21 09:27 AM
08/20/21 09:27 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
So it happens when you are releasing the clutch? Sounds like it would be a throwout bearing...
JB Rhinehart, Realist
A-Body's RULE!
Re: Clutch question [Re: Rhinodart] #2955606
08/20/21 10:01 AM
08/20/21 10:01 AM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
Yes, when I release the clutch. But as I mentioned, it's not doing it every time, at least not yet. I need to take it for another drive and see if it makes the grinding sound when I put it in the other gears.
Re: Clutch question [Re: Rhinodart] #2955623
08/20/21 10:58 AM
08/20/21 10:58 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
A T/O bearing should do it whether it's in gear or not but it could also be just on the edge of failing IE: sometimes does or doesn't make noise.
1. In neutral, hold the clutch in for a minute or two and the slowly release it. if no noise proceed to the next steps.
2. Try 1st gear again, if the noise is present, proceed to step 3
3.Try reverse and or a second gear take off
NOTE: it may not be as noticeable during gear changes as the clutch is typically released quicker and the car is moving
If it is only present when releasing the clutch in gear it could be the T/O bearing, a worn disc with the springs hitting the flywheel bolts, a loose flywheel or several other undesirable problems.
try the above and report back beer
Re: Clutch question [Re: TJP] #2955662
08/20/21 12:58 PM
08/20/21 12:58 PM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
I did what you suggested. Apparently. things have changed since the car cooled down overnight. I did step one and the first time I let the clutch pedal up there was no noise. Each subsequent time I pushed it down and let it up the grinding sound was there. I proceeded to step two and it makes the grinding sound when I try all the gears including reverse and now the transmission will not go into any gear. It would still go into all the gears last night while it was hot.
Re: Clutch question [Re: 1970RT] #2955767
08/20/21 06:04 PM
08/20/21 06:04 PM
Washington
madscientist Offline
Washington
Pilot bushing/bearing. That’s what makes that noise.
Re: Clutch question [Re: 1970RT] #2955806
08/20/21 09:07 PM
08/20/21 09:07 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
You can drop the inspection cover for a looksee, but it sounds like it's time to pull the trans & clutch to identify what's going on frown Keep us posted beer
Re: Clutch question [Re: 1970RT] #2955862
08/20/21 11:42 PM
08/20/21 11:42 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Is it ONLY a Noise you're hearing? Or can you FEEL (via your foot) any "ruffness" when you depress pedal with engine running.
Re: Clutch question [Re: 1970RT] #2955950
08/21/21 11:59 AM
08/21/21 11:59 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Quote
Was the above done with the car in neutral or a gear position ?
Quote
The above would indicate that the clutch is not disengaging or the synchonizers are not stopping the gears. This can be caused by the temperatures, wrong fluid or worn syncho's
Quote
Was the grinding still present when hot?
your posting's are a bit confusing and It's difficult to establish if the grinding you refer to is Transmission or clutch related
frown
If the noise is happening in Neutral WITHOUT MOVING the shifter then it is likely clutch related.
If the noise is happening WHEN MOVING the shifter and the clutch depressed it could be either or
Silly question, has the fluid level been checked recently?
As previously mentioned it sounds like it time to pull the trans. and clutch frown
Re: Clutch question [Re: TJP] #2956718
08/23/21 07:33 PM
08/23/21 07:33 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Will it make the noise when not running,if so lube the front bearing retainer snout that the bearing yoke slides on?
Re: Clutch question [Re: 71GTX471] #2956777
08/23/21 10:16 PM
08/23/21 10:16 PM
WI
Dcuda69 Online content
Dcuda69  Online Content
WI
Input shaft bearing? Changes with temp because lube thins out?
Re: Clutch question [Re: PhillyRag] #2956825
08/24/21 07:29 AM
08/24/21 07:29 AM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
I don't feel anything unusual with the pedal and the grinding sound is intermittent.
Re: Clutch question [Re: TJP] #2956826
08/24/21 07:35 AM
08/24/21 07:35 AM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
Quote
Was the above done with the car in neutral or a gear position ? Both.
Quote
Quote
Was the grinding still present when hot? It does it both when hot after the engine has been running a while and also as soon as I start it before it gets hot.
frown
Silly question, has the fluid level been checked recently? No.
Re: Clutch question [Re: 71GTX471] #2956827
08/24/21 07:37 AM
08/24/21 07:37 AM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
Yes, it does but not consistently.
Re: Clutch question [Re: 1970RT] #2956829
08/24/21 07:44 AM
08/24/21 07:44 AM
Metro Detroit
1970RT Offline OP
1970RT  Offline OP
Metro Detroit
I backed the car out of the garage yesterday and surprisingly it didn't make any grinding sound so I thought I would take it down the street and back. It now went in and out of all gears just fine and I didn't hear any noise. shruggy However, after I pulled it back in the garage there was a mild odor like that of something burning or overheating. I'm going to pull the trans./clutch as soon as I have time and find out what's going on.
