68 proportioning brake valve #2954977
08/18/21 10:29 AM
08/18/21 10:29 AM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
Has anyone rebuilt one ? is there a way to test it - working on the wago - redoing the lines and the p valve is just crusty - I see many replacements on line cheap enough - but am I better with original then new ? thanks
68 Satellite Wagon and a few other ones
Re: 68 proportioning brake valve [Re: mro] #2954987
08/18/21 11:23 AM
08/18/21 11:23 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i don't consider those to be proportioning valves. they're just distribution blocks with a safety built in. i'd just take the one you have apart and see how cruddy it is inside first before i bought one. they're pretty simple. proportioning is built into the master cylinder .
Re: 68 proportioning brake valve [Re: mro] #2955019
08/18/21 01:09 PM
08/18/21 01:09 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Does the car have disc brakes? Does the plumbing look like this? If so:
https://www.classicindustries.com/product/1968/dodge/charger/parts/mp500503.html
Re: 68 proportioning brake valve [Re: John_Kunkel] #2955042
08/18/21 02:27 PM
08/18/21 02:27 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
no drum
Re: 68 proportioning brake valve [Re: mro] #2955043
08/18/21 02:50 PM
08/18/21 02:50 PM
Rio Linda, CA
Rio Linda, CA
Re: 68 proportioning brake valve [Re: John_Kunkel] #2955190
08/18/21 10:19 PM
08/18/21 10:19 PM
VA
dragon slayer Offline
VA
Just some o rings and plunger and spring. Easy to take apart if it is clogged. Kits with O-ring are available for get name of the company. They are Mustang people I believe.
