What size replacement accelerator pump diaphragm? #2954886
08/17/21 10:12 PM
08/17/21 10:12 PM
East Bay, N. Cal.
calmopar Offline OP
calmopar  Offline OP
East Bay, N. Cal.
I've got a Holley 4150 850CFM with vac secondaries. Leaking from accelerator pump. Want to get a new diaphragm, but they seem to have 2 sizes, 135-9 which is 50cc, and 135-10 which is 30cc. Any clue which is stock for that carb? Also, should I be buying Holley brand or some 3rd party? TIA
Trying to enjoy life!
Re: What size replacement accelerator pump diaphragm? [Re: calmopar] #2954895
08/17/21 10:40 PM
08/17/21 10:40 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Having the Holley list number would probably help
Re: What size replacement accelerator pump diaphragm? [Re: Sniper] #2954899
08/17/21 11:00 PM
08/17/21 11:00 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
50cc on the left 30cc on the right. Noticeable difference. According to this article...all 4150/4160 carbs came with 30cc pumps on the primary side
https://www.holley.com/blog/post/accelerator_pump_tuning_for_holley_carburetors/
As stated...enter your carb list# here(on the airhorn) and you should find all the original specs for the carb
https://www.holley.com/support/carburetor/
Re: What size replacement accelerator pump diaphragm? [Re: Dcuda69] #2954906
08/17/21 11:17 PM
08/17/21 11:17 PM
GMP440 Offline
GMP440  Offline
Look at the well that the accelerator pump fits in. If it's deep and the taller diaphram fits in perfectly, then it's the taller diaphram. If it's shallow the shorter fits in.
Also, make sure you use the appropriate spring for the diaphrams. Tall spring spring for tall diaphram, short spring for the short diaphram. If you accidentally threw away the diaphram just look at the well and spring and that will tell you which one.
Re: What size replacement accelerator pump diaphragm? [Re: Sniper] #2954907
08/17/21 11:19 PM
08/17/21 11:19 PM
East Bay, N. Cal.
calmopar Offline OP
calmopar  Offline OP
East Bay, N. Cal.
The throat is stamped:
80531
1588
Re: What size replacement accelerator pump diaphragm? [Re: Dcuda69] #2954908
08/17/21 11:20 PM
08/17/21 11:20 PM
East Bay, N. Cal.
calmopar Offline OP
calmopar  Offline OP
East Bay, N. Cal.
Thanks I'll pop it in there.
Re: What size replacement accelerator pump diaphragm? [Re: calmopar] #2954909
08/17/21 11:24 PM
08/17/21 11:24 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Also, make sure the cover is flat - they get distorted from over-tightening.
Grab some 320 or 400-grit, place on a dead flat surface, and rub the cover across it.
It'll be easy to see if it's flat, and/or when you get it that way.
Re: What size replacement accelerator pump diaphragm? [Re: Dcuda69] #2954911
08/17/21 11:29 PM
08/17/21 11:29 PM
East Bay, N. Cal.
calmopar Offline OP
calmopar  Offline OP
East Bay, N. Cal.
I'm having a devil of a time figuring out what # that web page input wants.
I've tried 80531, R80531, 4150, 0-80531, and I get "no results." I will take it apart and eyeball it using the tips posted here - thanks!
Re: What size replacement accelerator pump diaphragm? [Re: topside] #2954912
08/17/21 11:29 PM
08/17/21 11:29 PM
East Bay, N. Cal.
calmopar Offline OP
calmopar  Offline OP
East Bay, N. Cal.
Thanks, will, do!
Re: What size replacement accelerator pump diaphragm? [Re: Dcuda69] #2954945
08/18/21 08:05 AM
08/18/21 08:05 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I think your question has been answered. If its not 30cc, it would be because someone changed it.
Re: What size replacement accelerator pump diaphragm? [Re: topside] #2954951
08/18/21 08:35 AM
08/18/21 08:35 AM
God's Country Maryland
GODSCOUNTRY340 Offline
I agree, I've had to file many accelerator pump covers when a new diaphragm wouldn't seal. Common Holley problem.
Re: What size replacement accelerator pump diaphragm? [Re: GODSCOUNTRY340] #2954959
08/18/21 09:05 AM
08/18/21 09:05 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
50cc cover on the left and 30cc on the right.
Re: What size replacement accelerator pump diaphragm? [Re: BSB67] #2954980
08/18/21 10:45 AM
08/18/21 10:45 AM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
iagree
