What size replacement accelerator pump diaphragm?
#2954886
08/17/21 10:12 PM
08/17/21 10:12 PM
Posts: 12,802 East Bay, N. Cal.
calmopar
East Bay, N. Cal.
I've got a Holley 4150 850CFM with vac secondaries. Leaking from accelerator pump. Want to get a new diaphragm, but they seem to have 2 sizes, 135-9 which is 50cc, and 135-10 which is 30cc. Any clue which is stock for that carb? Also, should I be buying Holley brand or some 3rd party? TIA
Trying to enjoy life!
Re: What size replacement accelerator pump diaphragm?
[Re: Dcuda69]
#2954906
08/17/21 11:17 PM
08/17/21 11:17 PM
Posts: 1,637 Florida
GMP440
Look at the well that the accelerator pump fits in. If it's deep and the taller diaphram fits in perfectly, then it's the taller diaphram. If it's shallow the shorter fits in. Also, make sure you use the appropriate spring for the diaphrams. Tall spring spring for tall diaphram, short spring for the short diaphram. If you accidentally threw away the diaphram just look at the well and spring and that will tell you which one.
[Re: Sniper]
#2954907
08/17/21 11:19 PM
08/17/21 11:19 PM
calmopar
East Bay, N. Cal.
Having the Holley list number would probably help The throat is stamped: 80531 1588
[Re: Dcuda69]
#2954911
08/17/21 11:29 PM
08/17/21 11:29 PM
calmopar
East Bay, N. Cal.
I'm having a devil of a time figuring out what # that web page input wants. I've tried 80531, R80531, 4150, 0-80531, and I get "no results." I will take it apart and eyeball it using the tips posted here - thanks!
[Re: topside]
#2954912
08/17/21 11:29 PM
08/17/21 11:29 PM
calmopar
East Bay, N. Cal.
Also, make sure the cover is flat - they get distorted from over-tightening. Grab some 320 or 400-grit, place on a dead flat surface, and rub the cover across it. It'll be easy to see if it's flat, and/or when you get it that way. Thanks, will, do!
[Re: Dcuda69]
#2954945
08/18/21 08:05 AM
08/18/21 08:05 AM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
...all 4150/4160 carbs came with 30cc pumps on the primary side
I think your question has been answered. If its not 30cc, it would be because someone changed it.
[Re: topside]
#2954951
08/18/21 08:35 AM
08/18/21 08:35 AM
Posts: 2,530 God's Country Maryland
GODSCOUNTRY340
Also, make sure the cover is flat - they get distorted from over-tightening. Grab some 320 or 400-grit, place on a dead flat surface, and rub the cover across it. It'll be easy to see if it's flat, and/or when you get it that way. I agree, I've had to file many accelerator pump covers when a new diaphragm wouldn't seal. Common Holley problem.
