Show me your trailer coupler lock !i #2953988
08/15/21 01:06 PM
08/15/21 01:06 PM
Florida STAYcation
dOc ! Offline OP
The village idiot's idiot
dOc !  Offline OP
Florida STAYcation
Gotta move my 24 foot Haulmark trailer(with that 27 roadster racer inside) from a locked, lighted and gated storage lot to now a parking space at my condo shop unit parking area. ..., what do you suggest for that 2 5/16 coupler ?
Here’s what appears to me to be the BESTest choice ... ur thoughts ?
Re: Show me your trailer coupler lock !i [Re: dOc !] #2954010
08/15/21 01:54 PM
08/15/21 01:54 PM
Florida STAYcation
dOc ! Offline OP
dOc !  Offline OP
Florida STAYcation
hay HAY ... 36 views and no suggestions ... tsk
Re: Show me your trailer coupler lock !i [Re: dOc !] #2954045
08/15/21 03:28 PM
08/15/21 03:28 PM
A727Tflite Offline
A727Tflite  Offline
I was hoping someone would post a good suggestion.
In the meantime, remove all the wheels, jack the nose up as high as you can using your electric jack if so equipped and disconnect the wire inside the jack motor.
If you leave the jack motor functional it can be hot wired. With it fully extended its hard to tow away with out the back dragging.
It doesn’t take too long to install 4 wheels and steal the trailer but it takes time to lower that jack.
Re: Show me your trailer coupler lock !i [Re: A727Tflite] #2954066
08/15/21 05:33 PM
08/15/21 05:33 PM
Out of the State of Confusion
blue_stocker Offline
And if possible, chain the tongue to something solid, immovable and substantial with a very hard lock. Don't recall the brand (sorry, no picture either) but I had a coupler lock that had the key slot/tumblers on the bottom so if somebody tried to bust it, it was one more uncomfortable/time-consuming/working up position for them...
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.
Thomas Jefferson
Freedom must be repurchased by every new generation
General Daniel Jones, WW2 Tuskegee Airmen
Re: Show me your trailer coupler lock !i [Re: blue_stocker] #2954097
08/15/21 07:27 PM
08/15/21 07:27 PM
Florida STAYcation
dOc ! Offline OP
dOc !  Offline OP
Florida STAYcation
thx bs and Tman ..... good ideas .... I have an additional few ... after two phone calls ....
BBL
Re: Show me your trailer coupler lock !i [Re: dOc !] #2954115
08/15/21 08:57 PM
08/15/21 08:57 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Saw the threads off a ball and get a pin lock for the latch is an option. Back it in so they can’t get your car out and take wheels off.
I want my fair share
Re: Show me your trailer coupler lock !i [Re: dOc !] #2954351
08/16/21 04:36 PM
08/16/21 04:36 PM
Mentor, OH
doggs330 Offline
doggs330  Offline
Mentor, OH
Someone had shared this video in response to the same question recently. Looks like the same lock you pictured in the original post.
Re: Show me your trailer coupler lock !i [Re: doggs330] #2954785
08/17/21 06:07 PM
08/17/21 06:07 PM
Florida STAYcation
dOc ! Offline OP
dOc !  Offline OP
Florida STAYcation
Damn d guy ... thx 4 that post !
Re: Show me your trailer coupler lock !i [Re: dOc !] #2954791
08/17/21 06:21 PM
08/17/21 06:21 PM
Florida STAYcation
dOc ! Offline OP
dOc !  Offline OP
Florida STAYcation
Anutter master lock ?
Re: Show me your trailer coupler lock !i [Re: dOc !] #2955030
08/18/21 01:45 PM
08/18/21 01:45 PM
moparx Offline
moparx  Offline
just WeLd it FaSt DoC.................. laugh2
nobody will thieve it then.
beer
Re: Show me your trailer coupler lock !i [Re: dOc !] #2955095
08/18/21 05:38 PM
08/18/21 05:38 PM
New York, USA
Chargerfan68 Offline
New York, USA
I use this exact one also. I’m sure thry could cut it off but it shoukld cost them some time and make some noise, which might deter them.
Re: Show me your trailer coupler lock !i [Re: Chargerfan68] #2955098
08/18/21 05:45 PM
08/18/21 05:45 PM
Florida STAYcation
dOc ! Offline OP
dOc !  Offline OP
Florida STAYcation
Cv ... the black or silver one ? Did you look at that vid ? Scary
Re: Show me your trailer coupler lock !i [Re: dOc !] #2955150
08/18/21 08:18 PM
08/18/21 08:18 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
I bought this from Walmart and loop it thru the the trailer tires. Definetely would slow them down
https://www.walmart.com/ip/TowSmart...e-with-Hitch-Lock-Vinyl-Coated/448463662
Re: Show me your trailer coupler lock !i [Re: nss guy] #2955159
08/18/21 08:30 PM
08/18/21 08:30 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Different approach
Re: Show me your trailer coupler lock !i [Re: FastmOp] #2955161
08/18/21 08:33 PM
08/18/21 08:33 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Heavy
Re: Show me your trailer coupler lock !i [Re: dOc !] #2955167
08/18/21 08:49 PM
08/18/21 08:49 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Inside battery. Cable thru the wheel connected to a hidden secondary dead mans pull switch. As soon as a wheel turns it pulls the cable and applies the brakes.
Doug
Re: Show me your trailer coupler lock !i [Re: dOc !] #2955243
08/19/21 08:37 AM
08/19/21 08:37 AM
New York, USA
New York, USA
The Other style black one.
Re: Show me your trailer coupler lock !i [Re: dOc !] #2955305
08/19/21 12:56 PM
08/19/21 12:56 PM
i use a chrome one like this on my trailer along with a latch lock, you can slow down thieves but you can't stop them unless you kill them hammer up devil
Re: Show me your trailer coupler lock !i [Re: Cab_Burge] #2955313
08/19/21 01:18 PM
08/19/21 01:18 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Nothing is better than making something yourself as they practice on commercial stuff to be ready for it. Some guys go as far as putting gps on their trailer that notifies you on your phone when the trailer is moved. Think outside the box.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Show me your trailer coupler lock !i [Re: pittsburghracer] #2955328
08/19/21 01:51 PM
08/19/21 01:51 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Problem is almost all these thieves these days bring cordless cut-off tools or cordless sawzalls.
Takes all of 1 minute to cut thru.
These locks are only good to keep the honest people honest.
