Re: 64 coronet ?
[Re: dcr]
#295449
04/21/09 04:23 PM
04/21/09 04:23 PM
Yes, it's been done quite a bit.
Gives better weight distribution along with, like you said, later header use, better engine mounts etc.
It does put the motor really close to the firewall, though.
Re: 64 coronet ?
[Re: dcr]
#295451
04/21/09 04:30 PM
04/21/09 04:30 PM
Posts: 2,381 MD
Kevins493
MD
Just moves the mounts back. Yea it is bolt in. I did it on my '64 Fury that BobK has now. You can run the late headers and the oil pans fit as they would on a later car. A cross ram will not fit without "massaging" the firewall.
Re: 64 coronet ?
[Re: dcr]
#295453
04/21/09 04:55 PM
04/21/09 04:55 PM
Posts: 2,381 MD
Kevins493
MD
sorry for all these ? but i keep thinking of poss problems what about clutch linkage if I remember rigt not much room to move body pivot rearward
yes you would have problems with the linkage..
Re: 64 coronet ?
[Re: Kevins493]
#295454
04/21/09 05:02 PM
04/21/09 05:02 PM
Posts: 1,021 Chesapeake Va
BobK
Chesapeake Va
Also, you will have to modify the trans mount. Kevin did a great job on my (his) 64 Fury.
1964 Plymouth Fury x 2 1964 Plymouth Sport Fury
Re: 64 coronet ?
[Re: 383man]
#295457
04/21/09 08:12 PM
04/21/09 08:12 PM
Posts: 1,446 Maryland
Dads426
Maryland
Here is the mount we modified when using the late K-Member. Basically moved the box back and down using 2x3 tubing. Was able to use a later A/B body trans mount from Rock Auto for $7 vs. the $79 one from Imperial Services.
We did it because I had two sets of headers that fit later B-bodies and no early B-Body mounts, so it was cheaper to just put in a $60 K-Frame that I got off ebag.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
