Small Block, Meziere Pump, Radiator Fan Combo #2954170
08/16/21 06:57 AM
08/16/21 06:57 AM
Tulsa OK
Bad340fish Offline OP
Tulsa OK
Is anyone out there running a Radiator and Fan combo for an A-body that clears the meziere pump with a small block? My current setup has worked for a long time but I would like tp upgrade it. I see lots of people make a radiator and electric fan combo but some I see either have cheap fans, or the dimensions won't clear the Meziere pump. Kind of looking for a bolt in deal before Drag Week. Thanks for any info.
I have looked at Becool(which might work but to expensive), I have an email into cold case radiator, and one or two others I can't remember. I can look at the Champion setup and tell that it won't clear the pump.
Its an unlikely find this close to drag week but worth an ask. I am worried about reliability of my current hacked up Dodge Intrepid fans more than I am over heating.
68 Barracuda Formula S 340
Re: Small Block, Meziere Pump, Radiator Fan Combo [Re: Bad340fish] #2954171
08/16/21 07:07 AM
08/16/21 07:07 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
The Chevrolet SSR fan and shroud package is about the narrowest I could find , and it fits the core nicely.
But I am using a remote pump and shoving water into the center core plugs , so the pump isn't hanging off the front of the motor.
If you have 4" from pump to radiator , it will be close to right.
I seem to recall it being 3 5/8 " thick.
Re: Small Block, Meziere Pump, Radiator Fan Combo [Re: Bad340fish] #2954192
08/16/21 09:36 AM
08/16/21 09:36 AM
aZLiViN
J_BODY Online rolleyes
J_BODY  Online Rolleyes
aZLiViN
I’m using two smaller fans diagonal. The one on the left is set up “quick release” style so I have more room to roll the engine with a ratchet if needed. I’m race only so no shroud so can’t say how’d it work street duty.
Re: Small Block, Meziere Pump, Radiator Fan Combo [Re: J_BODY] #2954223
08/16/21 10:59 AM
08/16/21 10:59 AM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
I run one of these fan setups, with a universal northern/summit radiator. I run chevrolet style with passenger lower/drivers upper, but I'd consider a double pass if you can run both on the passenger side.
https://www.universalpartsinc.com/shopping/productDetails.aspx?i=750831&c=10328
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: Small Block, Meziere Pump, Radiator Fan Combo [Re: topfueldart] #2954417
08/16/21 06:57 PM
08/16/21 06:57 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I will be tackling this problem soon , it will have to be a 1 off custom piece it appears to fit it in nicely ( that Meziere snout is long )
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Small Block, Meziere Pump, Radiator Fan Combo [Re: bigdad] #2954420
08/16/21 07:06 PM
08/16/21 07:06 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I used a wizard rad with 3/4” shroud and 4 staggered puller fan in a abody with a moroso electric water pump. Fit like a glove.
Re: Small Block, Meziere Pump, Radiator Fan Combo [Re: Bad340fish] #2954563
08/17/21 09:17 AM
08/17/21 09:17 AM
bronx n.y
O
one bad fish Offline
O
bronx n.y
mine is a csr pump put it clears i would put pics but its a pain in the butt for lol
Re: Small Block, Meziere Pump, Radiator Fan Combo [Re: Bad340fish] #2954700
08/17/21 02:10 PM
08/17/21 02:10 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I used a Champion crossflow radiator and shroud for a early big block Camaro.
Also you can pick up about 3/4" by milling the recess off the timing cover and
and not using the Meziere block off plate.
"Just a Bracket car dressed up like a streetcar"
Re: Small Block, Meziere Pump, Radiator Fan Combo [Re: Just-a-dart] #2954758
08/17/21 04:48 PM
08/17/21 04:48 PM
Tulsa OK
Tulsa OK
That looks really good, my Dad and I were just talking about the timing cover modification this morning. I don't have time to rework much stuff before Drag Week so I ordered a Delta Pag 18" 4000CFM fan. Its only 2.1" thick at the edge and 2.7" in the middle. Not the cheapest option but I have wanted one for awhile because I can control its speed with my Megasquirt.
Re: Small Block, Meziere Pump, Radiator Fan Combo [Re: Bad340fish] #2962711
09/10/21 01:34 PM
09/10/21 01:34 PM
Tulsa OK
Tulsa OK
Cutting it close with the fan coming in last night. Its in and working but wired ugly due to time. Haven't driven the car yet but I can't imagine this not being better than what I had. It moves some air! 4000CFM and its not even that loud. The fan controller they offer is nice but I will probably move it to being controlled by my EFI to clear up some mess once drag week is over.
