What to do about windshield replacement #2954297
08/16/21 01:53 PM
08/16/21 01:53 PM
Seattle, WA
3
375inStroke Offline OP
Special needs person
3
Seattle, WA
What's everyone using for windshields? From what I've read, AMD, ECS, and Pilkington are fine for quality and thickness. Anything else is too thin.
Re: What to do about windshield replacement [Re: 375inStroke] #2954377
08/16/21 05:45 PM
08/16/21 05:45 PM
Thin is lighter up work
Re: What to do about windshield replacement [Re: Cab_Burge] #2954468
08/16/21 09:55 PM
08/16/21 09:55 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Pilkington, the others I have seen are wavy
Re: What to do about windshield replacement [Re: Cab_Burge] #2954628
08/17/21 12:19 PM
08/17/21 12:19 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Doesn't seal properly
Facts are stubborn things.
Re: What to do about windshield replacement [Re: larrymopar360] #2954873
08/17/21 09:24 PM
08/17/21 09:24 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
My car has a pilkington. Seems ok but I just got it so haven’t had time to notice if it’s thin.
I want my fair share
Re: What to do about windshield replacement [Re: larrymopar360] #2954940
08/18/21 07:30 AM
08/18/21 07:30 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
and doesn't fit well against the stainless trim
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: What to do about windshield replacement [Re: GoodysGotaCuda] #2955071
08/18/21 04:49 PM
08/18/21 04:49 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
Call around to your old glass shops and see if they have a PPG collecting dust.
China is the enemy.
Re: What to do about windshield replacement [Re: 1972CudaV21] #2955115
08/18/21 06:29 PM
08/18/21 06:29 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Over decades in the collision repair biz, I've seen flawed (wavy or ill-fitting) glass from both PPG & Pilkington.
PPG is supposedly the better of the two, but sometimes it's not.
Not sure where AMD or ECS is sourced, but hopefully they're checked before shipping.
Re: What to do about windshield replacement [Re: topside] #2955419
08/19/21 05:58 PM
08/19/21 05:58 PM
clarks summit pa
73cuda340 Offline
73cuda340  Offline
clarks summit pa
I had bad luck with an amd windshield. Brand new and within a month it Almost looks like the two layers of glass are separating. Called amd, and they didn't want to hear about it.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: What to do about windshield replacement [Re: 73cuda340] #2955595
08/20/21 09:19 AM
08/20/21 09:19 AM
MN
58pwrwgn Offline
58pwrwgn  Offline
MN
There is a dot number on the windshield. That will tell you who manufactured it.
