Re: What to do about windshield replacement
[Re: Cab_Burge]
#2954468
08/16/21 09:55 PM
08/16/21 09:55 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
Pilkington, the others I have seen are wavy
[Re: Cab_Burge]
#2954628
08/17/21 12:19 PM
08/17/21 12:19 PM
Posts: 15,900 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
What's everyone using for windshields? From what I've read, AMD, ECS, and Pilkington are fine for quality and thickness. Anything else is too thin. Thin is lighter Doesn't seal properly
Facts are stubborn things.
[Re: larrymopar360]
#2954940
08/18/21 07:30 AM
08/18/21 07:30 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
What's everyone using for windshields? From what I've read, AMD, ECS, and Pilkington are fine for quality and thickness. Anything else is too thin. Thin is lighter Doesn't seal properly and doesn't fit well against the stainless trim
[Re: GoodysGotaCuda]
#2955071
08/18/21 04:49 PM
08/18/21 04:49 PM
Posts: 3,267 Connecticut
1972CudaV21
Connecticut
Call around to your old glass shops and see if they have a PPG collecting dust.
China is the enemy.
[Re: topside]
#2955419
08/19/21 05:58 PM
08/19/21 05:58 PM
Posts: 1,180 clarks summit pa
73cuda340
clarks summit pa
I had bad luck with an amd windshield. Brand new and within a month it Almost looks like the two layers of glass are separating. Called amd, and they didn't want to hear about it.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
