Electrical Issue
#2953477
08/13/21 02:52 PM
08/13/21 02:52 PM
Posts: 1,335 Oregon
earlymopar
I’m having an electrical issue and would like some feedback. First a little background on what I’m working on in the hopes of getting direction from members here…
I’m working on an 81 D150 and found the Gear Vendors overdrive wouldn’t up or downshift. This is after proving the solenoid that shifts the overdrive was working correctly. This is also on a mechanically fresh overdrive unit. A gear vendors rep told me to by-pass the gear vendors electronic controller by wiring in a separate switch to the solenoid on the overdrive unit. This was a means to isolate where the problem may be. Simple enough.
The gear vendors solenoid has 2 terminals which have no-polarity. I ran a ground wire direct from the battery to one of the 2 solenoid terminals. Next, I wired-in a single pole, single throw LED switch using a fuse tap in a fuse location that is “on” when the truck is running (in this case the radio). This was the means to provide power to the switch. Then I ran a simple ground wire from the switch to the firewall. The final lead from the switch was the “On or LED” position out to the other solenoid terminal. This would only be energized when the switch rocker was moved to the LED or “On” position. The solenoid requires a 3 amp circuit which is the same as the radio.
When I went to start the truck, the fuel pump came on but the engine would not turn over. I checked fuses under the dash and all were OK. All of the wire connections were good. I thought I might have caused another lead to disconnect when pulling the (very) few wires needed to hook up the switch. All looked OK. Certainly, nothing else I did would seem to have caused an issue with this simple wiring job.
However, when I went to start the truck, I could hear the electric fuel pump running but the engine would not turn over. I re-traced the route of the wires I pulled and found nothing unplugged, shorted, etc. I did find a 30 amp fuse that was blown but I don’t know if that was blown before or after my work. This fuse is under hood and is one of 5 or 6 that were apparently added to replace the factory fusible links. I have to assume the fuse blew after I tried to start it since the truck started, ran and drove before I wired-in the switch. I replaced the fuse and disconnected all of the overdrive by-pass connections I made. The result is the same, the starter does not turn the engine over.
I'm at a loss as to what happened and why. Thoughts / Suggestions are appreciated.
Re: Electrical Issue
[Re: Sniper]
#2953484
08/13/21 03:37 PM
08/13/21 03:37 PM
Posts: 1,335 Oregon
earlymopar
Yes, Understood. This is made a lot more difficult in that it's not my truck and I didn't make any of the mods but all of that aside, I ran only one "positive" lead (from the fuse box) so I assume that has to be what caused the fuse to blow (unless it was blown before). Where is the NSS located from the factory?
[Re: stumpy]
#2953530
08/13/21 06:15 PM
08/13/21 06:15 PM
Posts: 1,335 Oregon
earlymopar
Good Point. This made me also wonder if the transmission wasn't fully in Park or was barely in and then slipped out after I shut the truck off (before I started the by-pass job).
