Re: Made it to the track, a little disappointed.
[Re: bee1971]
#2952668
08/10/21 10:20 PM
08/10/21 10:20 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Cudaman
This same 383 , before I turned it into a Stroker
Ran the 284 / 484 Mopar Camshaft for 20 years
Speed pro forged flattops
When I installed these same Edelbrock E Street heads that I am running now with that old camshaft
6,000 RPMs all day long if I wanted and higher , right up until I kissed some pistons with those same Eddy intake valves on the highway racing a Mustang
Hence , the new motor
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: 500ciBee]
#2952748
08/11/21 10:04 AM
08/11/21 10:04 AM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I won't change the cam. It drives around town well now and can do burnouts with a 21.5" wide tire. Ultimately, if you’re enjoying the car as-is, that’s all that really matters. Just keep in mind, a nice solid cam would retain most of the good drivability you’re enjoying now, and get the performance back to what you’re looking for. At the same time.......... it doesn’t sound like you’re at the track often enough to justify chasing the ET.
[Re: fast68plymouth]
#2952791
08/11/21 12:29 PM
08/11/21 12:29 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
I won't change the cam. It drives around town well now and can do burnouts with a 21.5" wide tire. Ultimately, if you’re enjoying the car as-is, that’s all that really matters. Just keep in mind, a nice solid cam would retain most of the good drivability you’re enjoying now, and get the performance back to what you’re looking for. At the same time.......... it doesn’t sound like you’re at the track often enough to justify chasing the ET. This is why I vote spray a 125 or 150hp n20 kit when it goes to the track. With all of that tire you could leave on the nitrous and with a ring swap you could move towards the 175-250hp jets which is when things start to get really exciting. You won't wear out a bottle while it sits in the trunk and if you are into car shows look at it this way; nobody can see if it's a 383 or a 511" engine from the outside but some nitrous solenoids make for a pretty good ooh-ahh to the non-performance and street performance folks. Just one guy's opinion. For extra cool points find a low deck fogger!
[Re: cudaman1969]
#2952798
08/11/21 12:42 PM
08/11/21 12:42 PM
Posts: 8,290 fredericksburg,va
cudaman1969
fredericksburg,va
New lifters? Adjustable rockers? Do you have adjustable rocker arms? If so you could do one more easy check.
