Page 3 of 3 1 2 3
Re: Made it to the track, a little disappointed. [Re: bee1971] #2952668
08/10/21 10:20 PM
08/10/21 10:20 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Cudaman
This same 383 , before I turned it into a Stroker
Ran the 284 / 484 Mopar Camshaft for 20 years
Speed pro forged flattops
When I installed these same Edelbrock E Street heads that I am running now with that old camshaft
6,000 RPMs all day long if I wanted and higher , right up until I kissed some pistons with those same Eddy intake valves on the highway racing a Mustang
Hence , the new motor
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Made it to the track, a little disappointed. [Re: bee1971] #2952673
08/10/21 10:42 PM
08/10/21 10:42 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
New lifters? Adjustable rockers?
Re: Made it to the track, a little disappointed. [Re: 500ciBee] #2952748
08/11/21 10:04 AM
08/11/21 10:04 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Quote
I won't change the cam. It drives around town well now and can do burnouts with a 21.5" wide tire.
Ultimately, if you’re enjoying the car as-is, that’s all that really matters.
Just keep in mind, a nice solid cam would retain most of the good drivability you’re enjoying now, and get the performance back to what you’re looking for.
At the same time.......... it doesn’t sound like you’re at the track often enough to justify chasing the ET.
Re: Made it to the track, a little disappointed. [Re: GTX MATT] #2952751
08/11/21 10:11 AM
08/11/21 10:11 AM
Lapeer, MI.
todd440 Offline
todd440  Offline
Lapeer, MI.
Maybe I missed the answer to Matt's question, but did you degree the cam when installing it?
Re: Made it to the track, a little disappointed. [Re: fast68plymouth] #2952791
08/11/21 12:29 PM
08/11/21 12:29 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Originally Posted by fast68plymouth
Quote
This is why I vote spray a 125 or 150hp n20 kit when it goes to the track. With all of that tire you could leave on the nitrous and with a ring swap you could move towards the 175-250hp jets which is when things start to get really exciting. You won't wear out a bottle while it sits in the trunk and if you are into car shows look at it this way; nobody can see if it's a 383 or a 511" engine from the outside but some nitrous solenoids make for a pretty good ooh-ahh to the non-performance and street performance folks. Just one guy's opinion.
For extra cool points find a low deck fogger!
Re: Made it to the track, a little disappointed. [Re: cudaman1969] #2952798
08/11/21 12:42 PM
08/11/21 12:42 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Do you have adjustable rocker arms? If so you could do one more easy check.
Page 3 of 3 1 2 3
