TF 270 Head Studs How long?
#2952349
08/10/21 09:38 AM
08/10/21 09:38 AM
Posts: 1,051 The Great White North
RAMM
I'm looking to use head studs on a forced induction build using TF 270's . There is nothing in stock but I'm sure head studs for another cylinder head may be close-problem is I can't find the stud length specs as part of a kit. On TF's site they list their bolt lengths as 4.300" for the long ones and 1.75" for all the short ones. Heck a SBC uses 34 head bolts in a 7/16" I may wind up ordering a SBC Head stud kit as long as I can find the correcct lengths or at least as close as possible. For example if anyone knows how long the head studs are for Indy 440-1 heads that would help. Thanks for any assistance. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
Re: TF 270 Head Studs How long?
[Re: RAMM]
#2952403
08/10/21 11:28 AM
08/10/21 11:28 AM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
All I can say is I used ARP-145-4206 on my TF270 build.
[Re: markz528]
#2952533
08/10/21 04:58 PM
08/10/21 04:58 PM
Posts: 14,498 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
All I can say is I used ARP-145-4206 on my TF270 build. That’s the part number for stock type and RPM type heads. I guess a little measuring between a stock head vs the TF head should give you an idea of how the fitment of those studs would be. I’m sure there would be no issues with the 12 short ones.
[Re: fast68plymouth]
#2952552
08/10/21 05:35 PM
08/10/21 05:35 PM
markz528
Morrow, OH
All I can say is I used ARP-145-4206 on my TF270 build. That’s the part number for stock type and RPM type heads. I guess a little measuring between a stock head vs the TF head should give you an idea of how the fitment of those studs would be. I’m sure there would be no issues with the 12 short ones. Its been a while, but my recollection is that I did a bit of research and that is what I was advised to use. They worked fine.
