Re: When to go to a Motor Plate
[Re: J_BODY]
#2952286
08/09/21 11:38 PM
08/09/21 11:38 PM
Posts: 11,552 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Plate if you want to relocate the engine, or lose the stock K-frame or torsion bars. I would put a mid plate in it if I used a front plate. Limiters too. Easy to get the trans in or out.
Buddy of mine has a big block stick car, 33-3400# maybe. Will go mid to low 9s with low 1.30 60s. Can go into the 1,20s if he gets after it. Solid steel mounts in the stock location.
[Re: CMcAllister]
#2952323
08/10/21 08:07 AM
08/10/21 08:07 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
I like the plates for all the reasons mentioned above. I love mine. Really nice being about to mount stuff to the plate so it all stays w/ the motor and not on the firewall or fenderwells.
Always heard solid stock style motor mounts distort the sides/cylinder walls of the block...especially in something that makes good power. Can't help but think there's truth to that given how much things move around in the block w/ loads placed here and there.
[Re: hudsonhornet7x]
#2952432
08/10/21 12:27 PM
08/10/21 12:27 PM
Posts: 43,163 Bend,OR USA
Cab_Burge
So if the whole front of the engine is on those bolts, does that cause added stress to the block?
I've had four cars, A B, and E bodies, two with elephant ears and two with front motor plates, no complaints or evidence of bad results from then running hundreds of passes so far as well as several thousand miles on the street with the elephant ears
#2952444
08/10/21 12:53 PM
08/10/21 12:53 PM
Posts: 31,027 Oregon
AndyF
I have never used a motor plate, but have been thinking about it. From what I see the plate uses the water pump bolts to hold it to the block. So if the whole front of the engine is on those bolts, does that cause added stress to the block? No, strength is not an issue with a motor plate. There are lots of other issues with motor plates but strength isn't one of them.
[Re: an8sec70cuda]
#2952447
08/10/21 12:56 PM
08/10/21 12:56 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I was told years ago by a person everyone knows, the thin cast stock blocks will distort and break. This is where the half plate "brace", rubber mount on the left, solid mount on the right deal for Stock Eliminator originated and was used a lot by others years ago.
#2952451
08/10/21 01:02 PM
08/10/21 01:02 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I have never used a motor plate, but have been thinking about it. From what I see the plate uses the water pump bolts to hold it to the block. So if the whole front of the engine is on those bolts, does that cause added stress to the block? Fasteners in the front of the block are being stressed in a different direction. The whole front of the block is used to attach the plate. As opposed to a 4" square section of the side of the block that is trying to be jerked directly away from the block at the hit. Use limiters and it is locked in.
[Re: Dragula]
#2952833
08/11/21 03:09 PM
08/11/21 03:09 PM
an8sec70cuda
There is a lot of beef around the water pump where a BBM plate bolts to...Never been an issue. And preferably, set your tabs up so it sits on the frame rails is the easy way to go. And always weld the brackets on the frame that the plate bolts to BEHIND the plate.
