Re: Aluminum Heads - Does anyone sell a true ready to run? [Re: hp383] #2931811
06/09/21 10:11 PM
06/09/21 10:11 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
I bolted on my TrickFlow 240 heads out of the box drive
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: Aluminum Heads - Does anyone sell a true ready to run? [Re: fast68plymouth] #2931872
06/10/21 07:56 AM
06/10/21 07:56 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
Originally Posted by fast68plymouth
The fact is, not all machine shops produce top quality work....... that’s just the way it is.
Aint that the truth! I have 3 engine projects going right now. Two of them were brought to me after work had already begun. Guess which is the only one that hasn't had to have corrective machining and/or major parts replacement done? It's shameful the quality of work that some shops churn out. The machine shop I use is more expensive than some others around here, but it's well worth it.
I can't imagine bolting an engine together w/o measuring EVERYTHING properly. The mentality of looking both ways before crossing a one way street applies here, lol.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Aluminum Heads - Does anyone sell a true ready to run? [Re: hp383] #2932252
06/11/21 11:48 AM
06/11/21 11:48 AM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
No way would I install a set of heads now without checking them out first. It is to the point now that I am taking new out of the box hydraulic lifters and oil pumps apart checking and cleaning them before using. Things are a mess as far as parts go.
Re: Aluminum Heads - Does anyone sell a true ready to run? [Re: metallicareload] #2932277
06/11/21 01:10 PM
06/11/21 01:10 PM
I've bought and used a bunch of new and used heads, none of the new ones, Indy, Edlebrocks or 440 Source had to issues with the guides and valve stems being to tight shock
Maybe I've been lucky shruggy
Or maybe not anal enough work
Re: Aluminum Heads - Does anyone sell a true ready to run? [Re: hp383] #2932386
06/11/21 11:34 PM
06/11/21 11:34 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
""But, does anyone sell a ready to bolt on and go aluminum head?""
I bought a set of Sidewinder heads from Todd which were advertised as ready to run. I bolted them on and I have had zero issues. I think that if you buy them from a pro vendor who advertises them as ready to go, you should be fine. But I would not buy a complete set of heads from a parts store and assume that they are ready to run.
Re: Aluminum Heads - Does anyone sell a true ready to run? [Re: YO7_A66] #2932424
06/12/21 09:02 AM
06/12/21 09:02 AM
NW Indiana
P
powertrip Offline
powertrip  Offline
P
NW Indiana
Bought a set of heads for my son's engine from a large volume rebuilder. They looked pretty out of the box, and the valvejob was actually decent. But all of the dirt and blasting grit in every single hole would have quickly destroyed the freshened engine.
I check, measure, blueprint, and clean every single part.
That's also why it takes me forever to get my stuff done.
Re: Aluminum Heads - Does anyone sell a true ready to run? [Re: powertrip] #2932426
06/12/21 09:05 AM
06/12/21 09:05 AM
NW Indiana
P
powertrip Offline
powertrip  Offline
P
NW Indiana
On the flip side, I have bought heads from 440 Source, Edelbrock, and ProMaxx that after a quick check were ready to go.
Re: Aluminum Heads - Does anyone sell a true ready to run? [Re: powertrip] #2933453
06/15/21 08:30 AM
06/15/21 08:30 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Trick flow are the nicest finished in the box head I have ever seen. I see them for Ford at engine systems all the time, and a couple mopes here and there. Every set I've seen look like the next. Very high quality VJ, and guide work. Most box heads make me nervous enough to pull them apart to check. Not TF. I think summit owns them now so no lack of funding.
Just for reference, a friend just bought a set of INDY hemi heads complete. I'll post a pic of how bad the VJ was. Took sinking the valve .03!!! to fix them. Most were only contacting the seats about half way around. Like they did the guides after the VJ lol.
The valve only made contact where the sharpe mark is. I guess that's indy's variable compression option. Increase spring pressure till the valve seats
Re: Aluminum Heads - Does anyone sell a true ready to run? [Re: dthemi] #2933485
06/15/21 09:45 AM
06/15/21 09:45 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
It took me a minute to see exactly what’s going on there....... then I could see the lap line.
That’s pretty “nice”.
Re: Aluminum Heads - Does anyone sell a true ready to run? [Re: dthemi] #2933659
06/15/21 06:10 PM
06/15/21 06:10 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I sent this to my machinist. He has a failed Hemi build in the shop now with a set of Indy heads just like that.
He thought the previous hacker that built the engine had produced that kind of work. I told him they probably came out of the box like that. He's a firm believer in if it comes out of a box, it's fk'd up but would not believe you could buy something THAT messed up.
Kevin
Re: Aluminum Heads - Does anyone sell a true ready to run? [Re: dthemi] #2933689
06/15/21 07:46 PM
06/15/21 07:46 PM
AndyF Offline
AndyF  Offline
Indy is infamous for their horrible valve jobs. I think most engine builders have learned by now that Indy ships heads complete just to save space. They don't intend the heads to be run out of the box, they assume that you'll take them apart and have them machined properly before putting them back together. Trick Flow heads come ready to run out of the box although it doesn't hurt to pull them apart and double check everything.
Re: Aluminum Heads - Does anyone sell a true ready to run? [Re: hp383] #2951902
08/08/21 11:00 PM
08/08/21 11:00 PM
Tampa Bay
BadFishy Offline
BadFishy  Offline
Tampa Bay
In case you're still looking, consider Marsh Performance Sidewinder heads. I got a set last winter. Took me YEARS to decide to pull the trigger and do what you are considering. Todd the machine shop owner is very good to work with and swapped out the springs to what I wanted at no charge. I did pay extra for him to bowl blend and clean up the castings. The fact that this was going to be done at his machine shop before being sent to me was the dealmaker. This combination is becoming hard to find, at least in Florida anyway. My very picky and knows his stuff engine man was impressed with the heads. He didn't need to re-do anything.
Wow, what a difference in performance from the plain ol' 3 angle valve job 452's that were on her before! I am very happy.
Take a look. Mighty pretty, huh?!
1971 Cuda, 440 custom-build
Re: Aluminum Heads - Does anyone sell a true ready to run? [Re: metallicareload] #2951911
08/08/21 11:35 PM
08/08/21 11:35 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I would never run any heads out of the box without checking them, aftermarket or OEM for that matter. I have one of the old sioux vacuum testers to check valve seal, you would be surprised how many new heads will not hold a vacuum. Funny thing is they all hold a vacuum after I touch up the seats. And I see lots of spring pressure ranges, cheap aftermarket to expensive, especially with a flat tappet camshaft, you have to verify the spring pressures. And I am relating issues that people bring me to fix after the fact. So I don't see I guess the ones that work out of the box, mainly the ones that don't.
Re: Aluminum Heads - Does anyone sell a true ready to run? [Re: jwb123] #2951935
08/09/21 05:52 AM
08/09/21 05:52 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
bad fishy,those marsh heads looks like mopar performance p5153524,on another note has anyone used these mp heads before
Re: Aluminum Heads - Does anyone sell a true ready to run? [Re: AndyF] #2951991
08/09/21 10:43 AM
08/09/21 10:43 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Andy,
Is this still true since the new owners took over?
Thanks,
Bill
Re: Aluminum Heads - Does anyone sell a true ready to run? [Re: dart games] #2952192
08/09/21 08:42 PM
08/09/21 08:42 PM
Tampa Bay
BadFishy Offline
BadFishy  Offline
Tampa Bay
They’re not MP - no MP casting number. Pretty sure they are the same castings as ProMaxx, but not stamped as ProMaxx on the ends.
Re: Aluminum Heads - Does anyone sell a true ready to run? [Re: BadFishy] #2952202
08/09/21 09:07 PM
08/09/21 09:07 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
ProMax buys their heads as raw as possible and they do their own seat, valve guides, and valve job work. I had a set of small block heads on my flowbench that a friend bought and they are very nice.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Aluminum Heads - Does anyone sell a true ready to run? [Re: hp383] #2953677
08/14/21 10:57 AM
08/14/21 10:57 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I would say if it is an unported head, then they should be cleaned and checked.
Usually just a bit of port cleanup and good valve job will improve airflow quite a bit.
The Trick Flow heads are CNC ported and they were good out of the box.
The Koffels ported B1 B/S heads were good out of the box.
The Hughes Engines Ported Max wedge Victors were good out of the box.
