Re: vapor lock ?
[Re: calrobb2000]
#2950610
08/05/21 08:45 AM
08/05/21 08:45 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
On my cuda, the best thing I did was go to a return style fuel system. I know that's not what you asked, but it made a HUGE difference when using pump gas on the street.
My dad's road runner has a stock style fuel system and seems to do fine. Admittedly he doesn't drive it much and it doesn't have nearly the amount of heat under the hood that my car does.
Re: vapor lock ?
[Re: Blucuda413]
#2950638
08/05/21 10:11 AM
08/05/21 10:11 AM
Posts: 145 NJ
cb1289
NJ
Only true fix is some sort of return line.
62 Dodge Dart Wagon
65 Plymouth Satellite
Re: vapor lock ?
[Re: cb1289]
#2950648
08/05/21 10:54 AM
08/05/21 10:54 AM
Posts: 12,384 Taxes & Virus's R-US, NY
Dragula
I will mention, you can do a return line/dead head system hybrid. I often use this on my return systems where I switch between carb & throttle body. So I typically run the return line from the regulator down on the frame rail, but then run it dead head up to the throttle body or carb. I typically do this on throttle body systems as opposed to full on efi system with fuel rails. Works really well. Potentially, you could still vapor lock it, so I run a heat shield over the dead headed section.
Some other tricks:
Paint the intake with a heat blocking paint. Stack a few carb gaskets underneath the carb. Holley carb heat shield Heat shield all the fuel lines Phenolic carb spacer
Re: vapor lock ?
[Re: Dragula]
#2950751
08/05/21 03:53 PM
08/05/21 03:53 PM
Posts: 8,163 Plymouth, MI
Blusmbl
Plymouth, MI
x2 on carb spacers. Isolate the carb as much as possible, either with plastic or wood.
Also try to find ethanol free fuel instead of E10 (or race gas), and make sure it's fresh. Winter blend fuel in the summertime is the worst combo for vapor lock.
Re: vapor lock ?
[Re: moparx]
#2951332
08/07/21 11:18 AM
08/07/21 11:18 AM
Posts: 27,467 So Cal
autoxcuda
So Cal
what heat shield material is that autox ? Firesleeve Lots of companies make/sell it: Aeroquip, Parker, DEI
Re: vapor lock ?
[Re: calrobb2000]
#2951369
08/07/21 01:16 PM
08/07/21 01:16 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
